Constant Hitting From Sub
Old Apr 20, 2003 | 01:06 PM
TegLover4life
Guest
Posts: n/a
Default Constant Hitting From Sub
Hey i recently installed my sub on my car witha 1200 watt amp powering it. I think it is able to handle the power becuase it was working... then i disconnected it so i could hide the wires, i blew a fuse some how. I replaced it but i still am getting this constant hit from my sub like even when it is in between songs. Any ideas on what it might be. I would like to fix it myself because i dont feel like paying the guys and car toys to do it. Thanks
Old Apr 21, 2003 | 09:01 AM
JTCdudeman's Avatar
Master H Technician
Default Re: Constant Hitting From Sub (TegLover4life)
Well... its one of two things... First try turning down the power leads and adjusting them on your amp... If that doesnt change anything which is likely... You need to hook your RCA jacks up to a different output jack. Most likely you blew it up and its totalled... Mine is hooked up to my rear outputs cause I blew the sub ones.... I bet you can fix by just adjusting the power on your amp...
deerman2701
Audio / Security / Video
15
Jun 11, 2008 05:51 AM
DC4R27
May 14, 2008 05:57 PM
Chi
Apr 7, 2008 12:17 PM
t0ekn3e
Jun 22, 2005 04:44 PM
EBP_SI
Apr 29, 2003 02:55 PM
