Removing Valve Cover
Old Apr 20, 2003 | 12:35 PM
optikal_blitz's Avatar
Default Removing Valve Cover
Hey i wanna paint my valve cover. Thinking gunmetal or a deep red. Anyway, i know i need some high temp paint and what not. My question is though..how do i safely and properly remove the valve cover? Are the bolts connecting it to the head tourqued? any vacum lines i should worry about (and while i'm at it..should i install a breather?)? Anyone willing to point me to a how-to guid would be greatly appreciated. Thanks!
--Ray
p.s.- It's an h23 if it makes any difference.
Old Apr 20, 2003 | 01:22 PM
GSxRated's Avatar
Default Re: Removing Valve Cover (NatakuBlitz)
1. Unscrew bolts
2. Remove
I painted my GSR's valve cover when I was a complete newb, there's nothing too it...just make sure you're careful not to tear the valve cover gasket or you will have a massive oil leak.
Old Apr 20, 2003 | 01:34 PM
rodrez.'s Avatar
When you put it back on, clean the oil off of the valve cover gasket and rubber seals in the spark plug holes, unless you're replacing them. Also, use a little RTV or Hondabond to make sure it seals up properly. DO NOT overtighten the bolts, they break easily.
Old Apr 20, 2003 | 03:07 PM
good deal, thanks a lot fellas. here i am sitting here shitting pineapples cause i'm worried about messing up vacum lines and gaskets.
--Ray
Old Apr 20, 2003 | 03:50 PM
rodrez.'s Avatar
Default Re: (NatakuBlitz)
Naw, no worries, the only line you'll have to pull off is the one that goes from your valve cover to your intake, it comes right off, and just slap it on when you're done. And remember to reconnect your ground wire.
Old Apr 20, 2003 | 03:53 PM
vicz's Avatar
Default Re: (rodrez)
just did this job on a h23.. pretty straight forward stuff.. if i were you, i would go to a autozone or advance and pick up a new valve cover gasket and spark plug gaskets.. just ask the guy and it will run you around 50 bux..
Old Apr 20, 2003 | 05:04 PM
rodrez.'s Avatar
Default Re: (LUDEatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LUDEatic &raquo;</TD></TR><TR><TD CLASS="quote">just did this job on a h23.. pretty straight forward stuff.. if i were you, i would go to a autozone or advance and pick up a new valve cover gasket and spark plug gaskets.. just ask the guy and it will run you around 50 bux.. </TD></TR></TABLE>
The gasket and plug rubbers should only less than that, from the dealer.
Old Apr 20, 2003 | 05:10 PM
SignfcntOthr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez &raquo;</TD></TR><TR><TD CLASS="quote">
The gasket and plug rubbers should only less than that, from the dealer. </TD></TR></TABLE>
What he said, but yea, since your in there, go ahead and replace all your gaskets and ****.
Old Apr 21, 2003 | 01:44 PM
good deal, thanks.
aystupet
Jun 30, 2010 05:00 PM
hondaracin24
May 8, 2005 11:40 AM
matman4444
Aug 23, 2004 08:32 PM
Dirk McGirk
Oct 5, 2003 05:56 PM
NONKonformyst
May 10, 2002 06:11 PM
