how much power??
Old Apr 20, 2003 | 08:42 AM
h2392si's Avatar
Default how much power??
tried to post before, no responce. i was thinking of putting some larger piping on my lude from the cat backto the muffler, 2.5" i believe, and a magnaflow muffler at the end. I could get it for 180$ installed and everything. I dont know if its mandrel bent though. Anyways what kind of gains should i expect to get if any? Is it even worth it, or is it even a good deal? Its a 92 si stick, with just an AEM shortram intake, by the way. Or is ti just for looks and sound? Any input is much appreciated, thanks in advance.
Old Apr 20, 2003 | 11:02 AM
BeavisB16's Avatar
Default Re: how much power?? (h2392si)
anywhere from 0-10 hp. 10 is really pushing it.
Old Apr 20, 2003 | 11:05 AM
psi420's Avatar
You could expect to see maybe 4-5hp, and a few more lbs/ft of torque in your mid-upper power band.
I think you will notice the most gain on your top end pull.
Old Apr 20, 2003 | 11:21 AM
joe_bocc's Avatar
Default Re: (psi420)
Expecting 10 hp is expecting a little too much. Around 5 hp gain is a little more reasonable.
Just make sure that the piping is mandrel bent. If it not, the odds are you probably won't gain any power over the stock exhaust.
LightningTeg
Apr 4, 2011 11:38 AM
Icey112
Jul 16, 2005 11:35 AM
vicz
Sep 27, 2002 07:57 AM
Jordan_4WS
Oct 5, 2001 01:21 PM
