Skunk2 Short Throw Shifter
You'll need a great shifter to improve on the feel of the stock one. The problem you (and I) are having is due to bad technique and nerves. Go to the root of the problem. Getting an aftermarket short shifter will only make the problem worse and cause you to miss more shifts. Just relax while shifting and don't think as much. These are the things I tell myself after I grind the gears.
You should consider getting a C's Short Stroke Shift.
Yes, it's a lot of money, but the stroke is noticeably shorter AND smoother. No rattles, no grinding.
nice japonese site ehe, is this it http://www.cs-comrade.co.jp/sss.html, how can I obtain info in english and where can I order this thing, any sites?
just stick with a stock shifter.
the only times i have missed a shift is with short shifters.
stock integra 94+ throw length isnt that bad anyway
Turtle
Aug 15, 2002 06:56 AM
