THOSE WITH JRSC how do you remove the PCV valve?
Old Apr 19, 2003 | 11:10 AM
The-LS's Avatar
Default THOSE WITH JRSC how do you remove the PCV valve?
Is there any tricks or tips to make this easier? I can barely see my PCV at all, and I don't think I should HAVE to remove a wholoe lot of parts to get to this. Anyone got suggestions? Thanks!
Old Apr 20, 2003 | 06:06 AM
hondamanwill's Avatar
Default Re: THOSE WITH JRSC how do you remove the PCV valve? (Black-LS)
what i do is remove the bracket for the exhaust the one that is bolted to the back of the block and then remove the breather box by twisting it out. istall the new pcv valve on the tank and then slide it back up you will have to get the other hose into the tank the one from the block to the can. good luck it has been done
Old Apr 20, 2003 | 08:03 AM
CRVRX's Avatar
Default Re: THOSE WITH JRSC how do you remove the PCV valve? (hondamanwill)
You should be able to remove the PVC with some angled long nose pliers.You can remove the water hose from the manifold so make more room.
Replace with a PVC that has a 90 deg hose comming off it, You can then change the brass fitting comming from the undernieth of the "S" tube on the blower to a 90 deg also. The hose will fit much better and will be easier to replace in the future.
Old Feb 23, 2006 | 07:41 AM
blufke's Avatar
Default Re: THOSE WITH JRSC how do you remove the PCV valve? (CRVRX)
Is there a method/recommended way of going about getting that other hose(one from block to box) and plastic fitting to pop into the box. I have been struggling with it for a few hours now. I barely have room for my hands in there so I got some long bent nose pliers but i still cant seem to get it. Any suggestions?
2001integra
Jun 11, 2008 08:52 PM
wompmaster
Mar 8, 2008 11:10 AM
EK FLY
Jul 30, 2005 10:14 PM
coupon
Dec 10, 2004 11:58 PM
