igniter question
Old Apr 18, 2003 | 02:38 PM
Hybrid Invasion's Avatar
Default igniter question
very simply put, how do i test to see if the igniter is good on an obd0 distributor? My b16 wont start in my crx, and i've checked the ecu, pins, grounds, etc and theyre all right, connected and snug. The coil is also heating and working.
Old Apr 18, 2003 | 04:33 PM
Default Re: igniter question (Hybrid Invasion)
bump...cmon guys, please help me out here. my cars sittin in a shop right now and we need to know how to test it because the guy isnt familiar with imports
Old Apr 18, 2003 | 04:45 PM
Chiovnidca's Avatar
Disconnect both wires from the coin and hook a test light between them. When you crank the engine the light should flash if the igniter is working. (This assumes everything before the igniter is good.)
Old Apr 18, 2003 | 04:53 PM
Default Re: igniter question (TurboD16Chiovnidca)
ok, and if it doesnt flash, can i use the igniter out of a d15b2 distributor, or am i not that lucky?
Old Apr 18, 2003 | 04:55 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Invasion &raquo;</TD></TR><TR><TD CLASS="quote">ok, and if it doesnt flash, can i use the igniter out of a d15b2 distributor, or am i not that lucky?</TD></TR></TABLE>
I should work.
Old Apr 18, 2003 | 05:04 PM
You sure? I've heard its a completely different distributor. I just want to make sure. I dont even know what it looks like in order to replace it.
Old Apr 18, 2003 | 11:38 PM
ejprimo's Avatar
they maybe interchangable b/c i used my old d16 igniter in my b16a distributor.
Old Apr 19, 2003 | 12:13 AM
cruznz's Avatar
did you check to see if there was spark at the plugs?
Old Apr 19, 2003 | 09:20 AM
Default Re: (cruznz)
no spark.
Old Apr 19, 2003 | 10:30 AM
Quik Chris's Avatar
Default Re: (Hybrid Invasion)
As long as it's the stame ignitor look as the one before it (3 contacts on top, one on the side) Doesn't matter if its NEC or HITACHI or anything.
Old Apr 19, 2003 | 07:35 PM
NonovUrbizniz's Avatar
Loved
Default Re: (Quik Chris)
fyi for the price of a new ignitor you can buy a msd cap and external coil...
Old May 19, 2003 | 08:10 PM
JDM_SiN_CiViC's Avatar
a new igniter at autozone is 40 bucks and works as good as a oem honda one, cause i am having the same problem and i checked aroudn to see if i could find one and its pretty cheap there i just hope its my igniter
rollinswapshop
Mar 15, 2011 03:11 PM
spooncivic01
Feb 3, 2008 05:30 PM
C-RICKS
Jul 3, 2004 02:06 PM
IntegD
Apr 2, 2004 10:16 AM
Carlito Brigante
Feb 28, 2003 06:49 AM
