How do you "sleeve" a block?
Old Apr 18, 2003 | 03:31 AM
sparq's Avatar
Default How do you "sleeve" a block?
If you buy a set of sleeves for a block - how the heck do you go about removing the old ones, and then replacing them with new ones?
Old Apr 18, 2003 | 05:41 AM
P1mpSlap's Avatar
You have to take it to a machine shop and get them to use a Multi-ton press to press them out.
Then press in the new ones.
Old Apr 18, 2003 | 05:42 AM
bryan305's Avatar
Default Re: (P1mpSlap)
I thought the old ones were cut out, then new ones pressed in....
Old Apr 18, 2003 | 06:23 AM
MikeMAN's Avatar
Default Re: (bryan305)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryan305 &raquo;</TD></TR><TR><TD CLASS="quote">I thought the old ones were cut out, then new ones pressed in....</TD></TR></TABLE>
yes, they old ones are machined out (usually on a CNC milling machine) and new ones are then pressed in.
mike
Old Apr 18, 2003 | 07:21 AM
PhatOptimo's Avatar
Default Re: (MikeMAN)
Re-sleeving is not a diy project.
Old Apr 18, 2003 | 07:28 AM
sparq's Avatar
Default Re: (Phat_Optimo)
Anyone know of any shops in upstate NY I can get it done at?
Old Apr 18, 2003 | 07:40 PM
int3gra's Avatar
Default Re: (sparq)
closest to u is payne dart i think its Minnesota.
other choices, golden eagle manufacturing (Cali)
darton sleeves
Old Apr 21, 2003 | 08:40 AM
X-Mazda 3 Racer's Avatar
Default Re: (int3gra)
Here is kind of an old article from Overboost. Check it out, but it is definately not a do it yourself job for sure!!!
http://www.overboost.com/story.asp?id=464
Old Apr 21, 2003 | 10:18 AM
sparq's Avatar
Default Re: (GoldenEagleMfg.com)
I was asking how it was done - not where I could get a CNC machine and press
But thanks, always wondered how it was done!
Old Apr 21, 2003 | 10:24 AM
92GSR2o3's Avatar
Default Re: (sparq)
Theres a shop in Brewster, NY that removs old sleeves and installs new ones, me an my friends use that place when we need machine work, they charge about 400 bucks to replace stock sleeves that price includes the sleeves as well. I belive the shop is called Extreme Motorworks. Hope that helps. Peace
Old Apr 21, 2003 | 10:40 AM
sparq's Avatar
Default Re: (92GSR2o3)
Ill have to check it out - thanks! Still not a short trip but a nice all day trip I guess!
Old Apr 21, 2003 | 10:47 AM
Black 2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phat_Optimo &raquo;</TD></TR><TR><TD CLASS="quote">Re-sleeving is not a diy project. </TD></TR></TABLE>
Old Apr 21, 2003 | 11:54 AM
Evs-One's Avatar
Solbros Owns Me
drilled out and pressed in....
83mm Darton Solid Deck pro kit in a B18C5 block, bored to 84.5
Old Apr 21, 2003 | 12:32 PM
psi420's Avatar
Default Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">drilled out and pressed in....
Looks like fun!
Old Apr 21, 2003 | 05:32 PM
Datum1Tuning
Guest
Posts: n/a
looking for any interesting in starting a business? Must have knowlegde of resleeving honda block and machine shop exp. Equipment are in-house.
Old Apr 21, 2003 | 06:28 PM
10K2HVN's Avatar
LOL!
Old Apr 21, 2003 | 07:53 PM
sparq's Avatar
Default Re: (ForumEngineering)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForumEngineering &raquo;</TD></TR><TR><TD CLASS="quote">looking for any interesting in starting a business? Must have knowlegde of resleeving honda block and machine shop exp. Equipment are in-house.</TD></TR></TABLE>English?
Old May 1, 2003 | 10:50 PM
Datum1Tuning
Guest
Posts: n/a
How do you prepare the block for sleeving? which offset do you used when CNC machining the block? by the center of each bore? anyone have any experience with this.
blackeg
Jan 25, 2007 06:17 PM
vteczone
Mar 5, 2006 11:22 PM
rattyrat
Sep 19, 2005 08:38 AM
CRX SiR T
Nov 29, 2003 06:58 AM
JDMCRX
Nov 26, 2003 04:21 AM
