FS: D16 internals
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lonefuzzy79 »</TD></TR><TR><TD CLASS="quote">Isn't 10:1 a higher compression ratio than stock, say for a D16Z6? Might be interested if the answer is yes!</TD></TR></TABLE>
Yea it is. I'm not sure about the Z6, but the Y8 has a 9.6:1 CR.
Are these for the Y8 or Z6? Because I think they have different CR's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swrdply400mrelay »</TD></TR><TR><TD CLASS="quote">
Are these for the Y8 or Z6? Because I think they have different CR's.</TD></TR></TABLE>
they do, z6 is 9.2:1, and y8 is 9.6:1 as stated above.
arent they the same bore though??? if you guys wanna make sure these will fit on/in your engines you can give arias a call..but they should..and oh, you are gonna get yer block notched for the eagles, as with all aftermarket rods
bump
bump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG »</TD></TR><TR><TD CLASS="quote">
bump
the newer version of eagle rods don't require notching the block (just depends if these rods are the newer version or not) , z6 and y8 are both 77mm stock bore.
bump
</TD></TR></TABLE>the newer version of eagle rods don't require notching the block (just depends if these rods are the newer version or not) , z6 and y8 are both 77mm stock bore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civicEX »</TD></TR><TR><TD CLASS="quote">
the newer version of eagle rods don't require notching the block (just depends if these rods are the newer version or not) , z6 and y8 are both 77mm stock bore.</TD></TR></TABLE>
Really? I thought they were 75mm bore...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocoupe »</TD></TR><TR><TD CLASS="quote">Last I checked they were 75mm bore 90mm stroke.</TD></TR></TABLE>
JV
11
Nov 20, 2003 04:44 PM
......j/k bump for a good seller
