Torque settings for aluminum flywheels?
Old Apr 17, 2003 | 07:52 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Torque settings for aluminum flywheels?
I just got my Clutchmasters stage 1 clutch and aluminum flywheel today, installing it tomorrow. I'm wondering if I should use the factory torque settings for the flywheel bolts, even though it's an aluminum flywheel?
Also the flywheel came with new allen-head bolts and lock washers (instead of 12-pt bolts) to be used for the pressure plate. Should I use those or stay with the original 12-pt bolts?
Old Apr 17, 2003 | 08:11 PM
poison's Avatar
Default Re: Torque settings for aluminum flywheels? (PatrickGSR94)
If no one checks, I will check my helms for ya at home
Old Apr 17, 2003 | 09:35 PM
Community Builder
Default Re: Torque settings for aluminum flywheels? (poison)
Well I have a Helms manual too, but I'm just wondering if I should use the same torque specs on the CM aluminum flywheel as I would on the stock steel flywheel?
Old Apr 17, 2003 | 09:43 PM
Kamin's Avatar
yes use the same specs as stock
and use the allen screws they gave you.
Old Apr 17, 2003 | 10:33 PM
Community Builder
Default Re: Torque settings for aluminum flywheels? (Kamin)
Alright cool.... guess I need to go buy a 6mm allen socket driver so I can use my torque wrench with it.
Old Apr 17, 2003 | 11:33 PM
leadfoot78's Avatar
USE thread lock for god's sake!!!!!!!why didn't any one mention that with all the flywheel bolts backing out on people.
Old Apr 18, 2003 | 06:06 AM
Community Builder
Default Re: Torque settings for aluminum flywheels? (leadfoot78)
ah yes, thank you for that also. should I use that on the flywheel bolts AND those allen-head pressure plate bolts?
Old Apr 18, 2003 | 09:18 PM
leadfoot78's Avatar
I dint think you need to use it on the pressure plate bolts but if you do don't get any of that stuff on ony of the friction surfaces.
2wheelhunter
Sep 12, 2006 09:36 AM
madswapper
May 1, 2005 05:01 PM
mdj_ge
Dec 7, 2004 12:49 PM
90dxhatch
Apr 7, 2004 05:13 AM
Dokta
Aug 31, 2002 12:04 PM
