FS: Downpipe (Beautiful). Works with D series and B $200
Old Apr 17, 2003 | 06:33 PM
Ri5e's Avatar
Default FS: Downpipe (Beautiful). Works with D series and B $150
Correction: I want $150, not $200
This will replace your CAT! So if you want to use a cat convertor, you must cut it about a foot shorter and reweld the flange.
Very nicely welded and this should cost like $400 to get it made at most shops.
Gorgeous peice, with flex pipe. Barely used. Works with D series motor (Drag or Revhard). Might have to modify it for any other manifold, but with the flex pipe welded in, it makes things easier. Should work with B series with slight modifications. Just cut and use clamps or reweld.
$150 plus shipping.
Old Apr 17, 2003 | 07:27 PM
SPOON_BeIgHtEeNsEe's Avatar
Default Re: FS: Downpipe (Beautiful). Works with D series and B $150 (4 Stroke)
u know if this will fit onto a greddy 18g kit?
Old Apr 17, 2003 | 08:04 PM
Ri5e's Avatar
greddy 18g uses a different bolt style for the turbo. not 5 bolt. 5 bolt is usually T3 or t3/t4
Forgot to mention, this is a 5 bolt style flange. fits any t3 or t3/t4. also there is an O2 sensor there for you people. If u have a B seriies, u need to plug up that hole and get an o2 bung welded near the end of the downpipe OR u can extend the o2 sensor using wires
Old Apr 17, 2003 | 08:30 PM
rjardy's Avatar
Default Re: FS: Downpipe (4 Stroke)
imed you
Rob
Old Apr 17, 2003 | 08:34 PM
the greddy is a 5 bolt... can u take a pic of the flange... im really interested...
Old Apr 17, 2003 | 09:03 PM
turbo_ef9's Avatar
Default Re: FS: Downpipe (SPOON_BeIgHtEeNsEe)
yes.. the 18g greddy turbo is a 5 bolt.. they just got that gay ugly pipe that connects to the 3bolt dp.. it loops up like your dp you have also.. take a pic of the dp.. looking from the pipe then to the flange... free bump...
Old Apr 17, 2003 | 09:10 PM
heres a pic of the greddy DP...
look at that crush bent DP
Old Apr 18, 2003 | 07:28 AM
EVILD16BSTD's Avatar
say i was wondering what the ID was is a 3" or 21/2". let me know i just might pick this up from you ASAP.
email me info @ evild16bstd@hotmail.com
Old Apr 18, 2003 | 10:09 AM
Ri5e's Avatar
Default Re: FS: Downpipe (EVILD16BSTD)
id is a litle less than 2.5.
as for that downpipe, its a 5 bolt, its kinda hard to tell if that'll work or not. what u can do if itdoesn't work, chop off that flange adn weld it onto this
Old Apr 18, 2003 | 10:23 AM
can u take a pic of the flange... im really interested in need it asap...
Old Apr 22, 2003 | 02:40 PM
Ri5e's Avatar
up, this is a good deal. $150...
Old Apr 22, 2003 | 03:18 PM
adhana2's Avatar
i am intersted let me know
Old Apr 22, 2003 | 05:54 PM
Ri5e's Avatar
Default Re: FS: Downpipe (adhana2)
let me know. aim: crvmonster
Old Apr 22, 2003 | 07:06 PM
rjardy's Avatar
I imed you.
Rob
Old Apr 22, 2003 | 07:27 PM
shortyz's Avatar
Default Re: FS: Downpipe (rjardy)
nice pipe!
bump for you
Old Apr 22, 2003 | 07:55 PM
MikeySpec's Avatar
Default Re: FS: Downpipe (shortyz)
Can i keep a/c in an integra with a drag mani/to4e?
Mikey
Old Apr 23, 2003 | 04:18 AM
Ri5e's Avatar
Default Re: FS: Downpipe (CivicMikey)
i'm not sure, it was made for a D series manifold. It depends, u might have to modify it a bit
Old Apr 23, 2003 | 04:31 PM
i want it....
Old Apr 25, 2003 | 09:01 AM
BoostedD15B7's Avatar
do you know what radius bent that u bend is? Im looking to make 3" for mine but no sure which radius to get
90HFCrX
Mar 15, 2019 03:48 PM
padelslo
Jul 21, 2012 01:51 PM
Casey
Nov 7, 2011 07:35 PM
1.8T_EG
Mar 13, 2004 02:46 PM
