FS: Downpipe (Beautiful). Works with D series and B $200
FS: Downpipe (Beautiful). Works with D series and B $150
Correction: I want $150, not $200
This will replace your CAT! So if you want to use a cat convertor, you must cut it about a foot shorter and reweld the flange.
Very nicely welded and this should cost like $400 to get it made at most shops.
Gorgeous peice, with flex pipe. Barely used. Works with D series motor (Drag or Revhard). Might have to modify it for any other manifold, but with the flex pipe welded in, it makes things easier. Should work with B series with slight modifications. Just cut and use clamps or reweld.
$150 plus shipping.
$150 plus shipping.
Re: FS: Downpipe (Beautiful). Works with D series and B $150 (4 Stroke)
greddy 18g uses a different bolt style for the turbo. not 5 bolt. 5 bolt is usually T3 or t3/t4
Forgot to mention, this is a 5 bolt style flange. fits any t3 or t3/t4. also there is an O2 sensor there for you people. If u have a B seriies, u need to plug up that hole and get an o2 bung welded near the end of the downpipe OR u can extend the o2 sensor using wires
Re: FS: Downpipe (SPOON_BeIgHtEeNsEe)
yes.. the 18g greddy turbo is a 5 bolt.. they just got that gay ugly pipe that connects to the 3bolt dp.. it loops up like your dp you have also.. take a pic of the dp.. looking from the pipe then to the flange... free bump...
say i was wondering what the ID was is a 3" or 21/2". let me know i just might pick this up from you ASAP.
email me info @ evild16bstd@hotmail.com
Re: FS: Downpipe (EVILD16BSTD)
id is a litle less than 2.5.
as for that downpipe, its a 5 bolt, its kinda hard to tell if that'll work or not. what u can do if itdoesn't work, chop off that flange adn weld it onto this
90HFCrX
03-15-2019 03:48 PM
padelslo
07-21-2012 01:51 PM
