... oil pressure and oil temp gauges... electrical or mechanical?...
Old Apr 17, 2003 | 05:29 PM
1.8T_EG's Avatar
Default ... oil pressure and oil temp gauges... electrical or mechanical?...
... just curious what everyone else's experiences/recommendations/thoughts are... lemme know... thanks...
Old Apr 17, 2003 | 05:40 PM
DeepSi's Avatar
Default Re: ... oil pressure and oil temp gauges... electrical or mechanical?... (1.8T_EG)
electrical
Mechanical
You dont want oil to be plumbing between the engine department and cabin. Which is what mechnical will most likely do.
Old Apr 17, 2003 | 05:58 PM
1.8T_EG's Avatar
Default Re: ... oil pressure and oil temp gauges... electrical or mechanical?... (DeepSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeepSi &raquo;</TD></TR><TR><TD CLASS="quote">You dont want oil to be plumbing between the engine department and cabin. Which is what mechnical will most likely do. </TD></TR></TABLE>
... is this true with a sender unit also?... confused...
... also, is it safe to say that if you have an aftermarket oil pressure gauge... you can disconnect the display in the stock gauge cluster?... or would this throw an error code of some sort?... i am asking because i was wondering if i could use this location for something else... lemme know... thanks...
Old Apr 17, 2003 | 06:44 PM
Tofurky's Avatar
it won't throw a code.
Old Apr 17, 2003 | 07:03 PM
bruthaboost's Avatar
Electrical is "safer", however I love the simplicity and response of mechanical gauges.
Old Apr 17, 2003 | 07:13 PM
1.8T_EG's Avatar
Default Re: ... oil pressure and oil temp gauges... electrical or mechanical?... (bruthaboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruthaboost &raquo;</TD></TR><TR><TD CLASS="quote">Electrical is "safer", however I love the simplicity and response of mechanical gauges.</TD></TR></TABLE>
is it true that all mechanical gauges route oil to the cabin?... if not, which ones dont?... thanks...
Old Apr 17, 2003 | 07:32 PM
DaveF's Avatar
all mechanical guages send oil into the cabin....how else would the guage work?????
and electrical guage has a presure sender that you would mount somewhere on the engine and it has wires that run into the cabin....
no oil in the cabin that way. but not as responsive. IMO
Old Apr 17, 2003 | 09:50 PM
XDEep's Avatar
Default Re: ... oil pressure and oil temp gauges... electrical or mechanical?... (2.2Lcivic)
well how many people have had oil spray in their face? i already got enough acne
Old Apr 17, 2003 | 11:45 PM
g2_boosted's Avatar
I have a Mechanical Oil Pressure gauge, Works fine and have never had any problems with oil in the cabin
Old Apr 17, 2003 | 11:53 PM
Tofurky's Avatar
Default Re: (g2_boosted)
it's the fact that you have an oil line inside your cabin. awesome
Old Apr 18, 2003 | 02:54 AM
XDEep's Avatar
Default Re: (Ruckus138)
speaking of gauges, what about liquid filled vs. dry
Old Apr 18, 2003 | 04:02 AM
RGAZ's Avatar
New User
Here is my input.
Mechanicals are very nice, they respond fast, have large 270deg sweep for cheap and they are actually more versitile.
Electricals are easy to wire, slower to respond, usually have crappy 90 deg sweep so they are not as accurate. You can get 270 deg sweep electrical, but they are 3 times the cost of the mechanical. Is that worth it?
As for liquid or dry, that is for engine mounted gauges or areas with alot of pulsed signal or vibration. If the signal has alot of pulsing or vibration, i.e. fuel pressure, the liquid filled will smooth the vibrations. A dry setup will just have a shaky needle.
HTH
Randy
Old Apr 18, 2003 | 04:09 AM
XDEep's Avatar
Default Re: ... oil pressure and oil temp gauges... electrical or mechanical?... (RGAZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGAZ &raquo;</TD></TR><TR><TD CLASS="quote">Here is my input.
HTH
Randy</TD></TR></TABLE>
what about the smoothness being laggy in applications where you want to see any instantaneous spikes, like with boost or a/f or electrical. the rest i guess you can deal with lag rather than it being shaky all the time, like oil pressure/temps.
Old Apr 18, 2003 | 04:42 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeepSi &raquo;</TD></TR><TR><TD CLASS="quote">electrical
Mechanical
What he said.
Old Apr 18, 2003 | 08:00 AM
RGAZ's Avatar
New User
Default Re: ... oil pressure and oil temp gauges... electrical or mechanical?... (XDEep)
All devices have inherent lag. It helps smooth the needle movement.
The A/F is electrical only so no deal there.
Boost will resond very fast and mechanical is really the only option.
Randy
elpiar
Oct 26, 2005 11:21 AM
CivicMike
May 26, 2005 09:34 AM
vtec.dc2
Mar 9, 2004 08:18 AM
roydogg
Nov 17, 2003 08:33 PM
sslude
Feb 25, 2003 08:31 PM
