Hesitation at 75-80 mph
Old Apr 17, 2003 | 01:40 PM
Eggman's Avatar
Default Hesitation at 75-80 mph
A friend's stock Integra occassionlly hesitation, strange thing is it's always at 75-80 mph. No codes on the stock ECU. Ignitor?
Old Apr 19, 2003 | 08:43 PM
Eggman's Avatar
Default Re: Hesitation at 75-80 mph (Eggman)
Old Apr 19, 2003 | 10:43 PM
GZERO's Avatar
it sounds to me (from the vague description) it is the tires, unbalanced or they might have a bump, just tell him to rotate them and balanced them.
Old Apr 20, 2003 | 09:47 AM
Eggman's Avatar
Default Re: Hesitation at 75-80 mph (GZERO)
It hesitates, like when you give it gas and it doesn't accelerate. It stutters.
Old Apr 20, 2003 | 10:10 AM
GZERO's Avatar
so it´s pretty much a constant vibration at a certaing speed? if soo, then my old reply is still standing, get the tires balanced and rotated and check for uneven thread or any bump either on the wheel or the tire. good luck
Old Apr 20, 2003 | 10:14 AM
Eggman's Avatar
Not a vibration or shaking of any kind. Absolutely not the tires. It's like you accelerate and the car starts to stutter like it's not getting gas, or like someone is pulling the spark plug wires out on you while your accelerating.
Old Apr 20, 2003 | 10:16 AM
GZERO's Avatar
is funny, your description sounds like a fuel cut or rev limiter, i would check the fuel system, filter, pump and injectors, but i don´t really feel confident to say exactly what is your problem. So this is more like a BUMP
EDIT: spel and coherence.
Old Apr 21, 2003 | 07:10 AM
1hottEG6's Avatar
Sounds like spark, but again could be a few things, i think ur right with ur original post. Ignitors arent too expesive and if u have a lot of miles on the car ur gonna need one sooner or later, even though never really hear of them taking a ****- good luck
Old Apr 21, 2003 | 10:01 AM
RSZero1's Avatar
Default Re: Hesitation at 75-80 mph (1hottEG6)
i'm actually running into the same problem, car cuts back on powere at about 85, till it hits about 60-65 then back into power. From what i've been told i either need to hook up my knock sensor, or change my dist, i'm running a hx dist on a ex eng and the ex doesn't have the knock hooked up properly...
Old Apr 22, 2003 | 11:55 AM
Eggman's Avatar
Default Re: Hesitation at 75-80 mph (RSZero1)
If it were the knock sensor, wouldn't the ECU throw a code?
Old Apr 22, 2003 | 12:06 PM
leadfoot78's Avatar
Yes the ecu would throw a code if knock sensor is not hooked up the right way. Some ecu wont even let you rev past 5k if the knock sensor is not working.
Old Apr 22, 2003 | 02:25 PM
blykins's Avatar
Banned
Default Re: Hesitation at 75-80 mph (leadfoot78)
Check your plugs.
Old Apr 22, 2003 | 03:24 PM
Eggman's Avatar
Default Re: Hesitation at 75-80 mph (blykins)
I'm pretty sure he changed the plugs already and the problem persisted.
Old Apr 22, 2003 | 05:05 PM
CRX_VTEC's Avatar
thinking distributor
philliesfan11
Honda Civic (2006 - 2015)
11
Sep 28, 2017 03:14 AM
4dek
Mar 23, 2009 04:52 PM
InTheLBC20
Dec 6, 2008 07:53 AM
B18c1vicrx
Jan 7, 2008 07:05 PM
dogbiscuit
39
Oct 1, 2005 05:19 AM
