Advance timing
Old Jun 27, 2001 | 11:35 AM
Ideal R's Avatar
New User
Default Advance timing
this may sound stupid but i am just a new baby so plz bear with me
just wonder what should i do to advance timing?
change cam gear or what?
and what is the optimal timing for ITR?
thx a lot!
Old Jun 27, 2001 | 11:53 AM
Big Phat R's Avatar
Default Re: Advance timing (ITR #01-1203)
Timing is advanced/retarded by moving your distributor (the thing that makes sparks for the sparkplugs) back and forth on its perch,. There is an adjustment screw very near to it that allows you to adjust the timing by moving it back/forth. This should be done by someone who knows what they are doing and using a timing gun.
Optimal timing depends on the engine (mod vs stock) and is best determined by timing your car on a track or on a dyno.
Old Jun 27, 2001 | 11:58 AM
Boba-Fett's Avatar
New User
Typically the ITR will give maximum power with bolt ons around 18 degrees of advanced timing.
When adjusting yourself with no timing light, only go about 1 mm to 3mm from stock.
Boba-who had to modify cuz he dont like no stinking metric system.
[Modified by Boba-Fett, 4:07 PM 6/27/2001]
Old Jun 27, 2001 | 12:02 PM
DutchITR1689's Avatar
Default Re: Advance timing (Boba-Fett)
When adjusting yourself with no timing light, only go about 1 cm from stock.
I think you guys (Americans?) are not comfortable with the metric system yet. It's 1 mm not 1 cm.
2.56 cm = 1 inch.
Old Jun 27, 2001 | 12:39 PM
Ideal R's Avatar
New User
thx guys!
so what is the optimal timing for stock ITR?
for ITR with only aem cai?
Old Jun 27, 2001 | 12:41 PM
Chris's Avatar
18 deg. But i dont suggest you try to set the timing yourself (especially without a light)....ask someone in your area with Integra expirence...its not as easy as moving the distributor.
Old Jun 27, 2001 | 12:43 PM
travis's Avatar
Default Re: Advance timing (Chris)
Does this help?
http://integra.vtec.net/engine/timing.html
Old Jun 27, 2001 | 02:39 PM
Jason's Avatar
I have a question about this timing thing...If you know it should be set to 18 degrees, and I know it should be set to 18 degrees, why doesn't HONDA? I mean, I'm sure they do, but there had to be a reason why it doesn't come that way from the factory. I'm not disagreeing w/ you (hell, I want to get a light and do it as well) but just an idea....there has to be a reason..
Old Jun 27, 2001 | 02:44 PM
Big Phat R's Avatar
Default Re: Advance timing (typer98)
probably for emissions. Honda is very GREEN
Old Jun 27, 2001 | 02:47 PM
Jason's Avatar
Default Re: Advance timing (Big Phat R)
what does it do to emissions? could it cause someone to fail an emissions test, say in CA where it's so strict?
Old Jun 27, 2001 | 03:22 PM
Big Phat R's Avatar
i dont know...but it's easy to switch back.
The 2000+ Rs are LEV so I doubt it would be a problem.
Old Jun 27, 2001 | 03:26 PM
Jason's Avatar
true, very true...oh well
Old Jun 27, 2001 | 04:18 PM
Chris's Avatar
Default Re: Advance timing (George Knighton)
If you set to 18 degrees initial advance, what's the total advance at speed?
That is an interesting point. A friend just installed the APEXi computer and I was watching the timing jump around and hit 40deg at around 3000 RPM!!!
I thought it was wrong....I guess not. I learn something new everyday!!!
Old Jun 27, 2001 | 05:25 PM
BABY NSX's Avatar
Honda specs are 16 +/- 2, therefore 18 is within spec! When I checked mine I noticed that it was set to 15 degrees.
I would not take it for granted that your timing is set to 16 degrees if you haven't touched it. It could be anywhere within the specs. Do it right, get a timing light! Also, I would not worry too much about setting it to 18 degrees as you are still within spec.
And yes even slight changes in timing will have a meaningful effect on the engines performance.
Regards,
Old Jun 27, 2001 | 06:24 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default Re: Advance timing (BABY NSX)
If you change your timing 18 degrees advance will it void the warranty? Will acura advance for you?
Old Jun 27, 2001 | 06:36 PM
Chris's Avatar
Default Re: Advance timing (01PYTypeR#1140)
Old Jun 28, 2001 | 01:05 AM
A Honda dealer did it for me, for free!!
Old Jun 28, 2001 | 04:58 AM
Ideal R's Avatar
New User
when i go to some garage yesterday, they don't know what i am talking about with the advance timing thing, werid...
anyway, what is the theory behind "advance timing give more power"?
thx
Old Jun 28, 2001 | 05:09 AM
Boba-Fett's Avatar
New User
Where's the info that backs this up claim on the ITR's? From what I was told the ITR isnt a LEV.
Boba- who could be wrong, but all 's & 's that Boba has ever seen has a sticker on the window that says LEV.
Old Jun 28, 2001 | 07:42 AM
jeff652's Avatar
Here's how much of a power difference advancing - or retarding - the timing will make on an ITR: (no other mods, just timing)
Jeff
Old Jun 28, 2001 | 08:48 AM
Default Re: Advance timing (jeff652)
Wow! I didn't know you can go that far (23 deg). Is that max. mechanical advance?
Old Jun 28, 2001 | 09:22 AM
jeff652's Avatar
Default Re: Advance timing (EuroITR1689)
I think you could go 25-27. Believe it or not, it was barely detonating at 23 degrees. But for peace of mind, I run it at 19 on the streets~
Chevron Premium all the way!
Jeff
sikek1
Apr 28, 2008 05:49 AM
kixcrx
Nov 10, 2006 10:33 AM
OneFastLS
May 25, 2002 03:12 PM
