Throttle Body Questions?
Old Apr 16, 2003 | 08:47 PM
StinkyTofu's Avatar
Default Throttle Body Questions?
I am considering getting a type R throttle body for my gsr. My current set up is a gsr throttle body on my skunk2 manifold. My tuner said i would see gains if i upgraded my throttle body and said mine was too restrictive. I always thought that going bigger in throttle body size meant better throttle response and not gaining any power?
The gsr throttle body is only 2mm smaller than the ITR one, can 2mm really make that much of a difference? The opening on the skunk2 manifold is 62mm (same as type R throttle body). So right now, i've got a 3 inch aem cai connected to my 60mm throttle body, back into a 62mm intake manifold. Will that disrupt airflow considerbly?
Old Apr 16, 2003 | 08:57 PM
sgT's Avatar
sgT
Default Re: Throttle Body Questions? (StinkyTofu)
manifold opening should be 64mm.
I would recommend the itr TB. but any larger probably wont help.
Old Apr 16, 2003 | 09:01 PM
MK Ultra's Avatar
Well, a TB's job is to disrupt airflow, sort of.
The differences in TB and IM diameter aren't something I'd worry about. I doubt it has as much effect on airflow as the throttle plate. As for power, I've never seen a TB make more power on an NA B-series, but every motor is different.
Old Apr 16, 2003 | 09:03 PM
sgT's Avatar
sgT
Default Re: Throttle Body Questions? (MK Ultra)
you want the opening to be a tad larger than the tb
Old Apr 16, 2003 | 09:06 PM
MK Ultra's Avatar
Default Re: Throttle Body Questions? (sgT)
Does that have anything to do with the fact that the air is going into a plenum, a reservior of air so to speak?
sgT's Avatar
sgT
anti-reversion effect.
TB < manifold
intake ports < runners
header primaries < exh ports
Old Apr 16, 2003 | 09:10 PM
MK Ultra's Avatar
Ah, didn't realise reversion was as much a consideration that far upstream the intake tract.
Thanks.
Old Apr 16, 2003 | 09:11 PM
StinkyTofu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">you want the opening to be a tad larger than the tb </TD></TR></TABLE>
Oh, so the way its set up right now is ok? I always thought the skunk2 manifold had a 62mm opening? Another question i had is about the throttle bodies that have a tapered design. Take spoon for example, they have a 70mm opening tapered down to 62mm. Whats the point in doing that? And if having a larger opening than the throttle body is ideal, why do some shops offer "port-matching" services for the throttle body and intake manifold? oh yeah, thanks for the help btw.
Old Apr 16, 2003 | 09:13 PM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StinkyTofu &raquo;</TD></TR><TR><TD CLASS="quote">
Oh, so the way its set up right now is ok? I always thought the skunk2 manifold had a 62mm opening? Another question i had is about the throttle bodies that have a tapered design. Take spoon for example, they have a 70mm opening tapered down to 62mm. Whats the point in doing that? And if having a larger opening than the throttle body is ideal, why do some shops offer "port-matching" services for the throttle body and intake manifold? oh yeah, thanks for the help btw. </TD></TR></TABLE>
stock TBs are tapered as well.
GSR should be 64-60 or 62-58 (i really needto get around to measuring mine)
itr is 66-62
Old Apr 21, 2003 | 08:19 PM
Shark Tank's Avatar
any advantages going to a 64mm or 70mm plate throttle body like the str, aem, ericks type TBs
Old Apr 21, 2003 | 08:38 PM
seanb18c1's Avatar
I just put an ITR TB on my GSR with a Skunk2 IM last week. While i was at it, I also put a Hondata IM gasket on. The top end feels stronger , but i won't know for sure until i go to the track.
EJtypeR
Jun 17, 2015 08:01 PM
tegSB85
Nov 17, 2005 05:50 AM
Fink2iCe
Aug 20, 2004 10:50 AM
EMO-anthony
May 6, 2004 04:12 PM
