crx ball joint prob
Old Apr 16, 2003 | 06:29 PM
inspecta83's Avatar
Default crx ball joint prob
i know this is a dumb question but....im trying to tighten the castle nuts that hold the ball joints in, and everytime i try to tighten it, the whole dam thing spins, getting me no where fast. someone please tell me how to do this...thanks alot.
Old Apr 16, 2003 | 06:37 PM
civbeater90's Avatar
Default Re: crx ball joint prob (inspecta83)
upper or lower?
Old Apr 17, 2003 | 01:03 PM
inspecta83's Avatar
lower
Old Apr 17, 2003 | 01:11 PM
nick.na's Avatar
Default Re: (inspecta83)
need a pickle fork
Old Apr 17, 2003 | 01:13 PM
nick.na's Avatar
need a pickle fork anyone know the real name for this??? i know the tool not the name tho
Old Apr 17, 2003 | 01:43 PM
slowpokesi's Avatar
Default Re: (amber-bling)
ball joint separator
Old Apr 17, 2003 | 02:30 PM
nick.na's Avatar
Default Re: (slowpokesi)
thanks...anywyas...this tool whether used on the upper or lower ball joint puts enough pressure to keep that biotch from slippin pretty self explanitory once you see the tool and shh what is spinning when you turn the castle nut. good luck bro
btw...not a dumb question...I just replaced my ball joints and had to ask too
Old Apr 17, 2003 | 03:20 PM
Outsane's Avatar
when ever do the lower, I clean up the spindle real good, and the hole its going into and drop it in there, if that doesn't make it stick I use a spare jack on the lower control arm to put some pressure on it..
The other two ball joins I usually tap a few times with a breaker bar.. to settle the spindle..
innes887
Apr 12, 2007 04:03 PM
joker4096
11
Feb 25, 2007 07:56 AM
M15
Jan 19, 2007 02:44 PM
VisualEcstasy
Mar 21, 2003 04:13 PM
