Compression test
Old Apr 16, 2003 | 03:56 PM
RCautoworks's Avatar
Default Compression test
When I was doing a compression test today, I kept hearing like a pop sound. I was just curious to what it was. I'm guessing its the air in the other cylinders shooting out.
Old Apr 16, 2003 | 05:01 PM
WalkmanX's Avatar
Default Re: Compression test (90blackcrx)
it could just be the instrument popping, did you feel your hand shake or nething?
Old Apr 16, 2003 | 05:09 PM
poison's Avatar
was your spark plugs out?
also smell around, check to make sure you didn't fart
it's probably compression pressure.
Old Apr 16, 2003 | 05:41 PM
tilt's Avatar
you should pull out all the plugs anyways... at least that is the way i learned to do it.
Old Apr 16, 2003 | 07:56 PM
acuratech's Avatar
We just tested a b18c1 with itr internals today. It did the same thing. Normal, don't worry about it.
Old Apr 16, 2003 | 08:17 PM
Default Re: Compression test (acuratech)
Yeah I pulled the plugs and no I did not fart . I was not worried , just curious.
Old Apr 16, 2003 | 09:07 PM
MikeSarr_GSR's Avatar
watch out
I just did
Old Apr 16, 2003 | 09:21 PM
teknoracing's Avatar
Just curious, what kind of numbers did you get for each cylinder?
Old Apr 16, 2003 | 09:54 PM
Default Re: Compression test (teknoracing)
210 all around on a 00 si. I have a first generation b16 and the head gasket is stock and I pulled 235 all around.
Old Apr 17, 2003 | 05:36 AM
ScottEK's Avatar
First gen at 235, doesn't that show some pretty heavy carbon build up, I believe new is at 185 and min is 135, so 235 is pretty out of the ballpark.
For high numbers can you pull the head and physically clean the cylinders and tops of pistons to remove carbon build up or do you have to go get it honed or something similar?
Old Apr 17, 2003 | 08:03 AM
Default Re: Compression test (beta13)
Yeah it is pretty high but its nothing to worry about, as long as the numbers are close to each other then its fine. Also I just did the compression test on a 00 si civic and the numbers were 210 across the board and the engine is only like 2 years old. I have heard the b16 compression is usually alittle high. By the way, if your check engine light is on and you do a compression test, that has no effect on it right ?
RyanWhite
12
May 31, 2015 09:36 AM
WhiteEJCoupe
Mar 19, 2010 03:35 PM
fakeownzjoo
Sep 21, 2006 04:31 PM
zracer240
Apr 24, 2005 08:35 AM
smslude
Feb 25, 2003 10:40 AM
