Engine Overheating
Old Apr 16, 2003 | 11:42 AM
turkcivic's Avatar
Default Engine Overheating
wus up guys. when my car is not moving and the engine is on for about 5 to 10 min sometimes my engine overheats when i start to drive it goes back to the normal temp. I hve a 2000 honda civic si do any of you know why it is doing this.
Old Apr 16, 2003 | 12:40 PM
JimBlake's Avatar
Default Re: Engine Overheating (turkcivic)
Because when the car's not moving, there's not much air moving thru the radiator. You should see the temperature gauge move up somewhat, then the radiator fan starts to run & it comes back down. But how high does the gauge go?
If it goes into the red, then its too much. Fan switch, wiring, relay, or fan motor itself could be bad... Got a repair manual?
Old Apr 17, 2003 | 01:30 PM
Kazz's Avatar
Hey whats up
theres a couple things to look at.
Radiator cap,
thermostat,
belt to the water pump could be loose
the radiator itself
try those first
Old Apr 17, 2003 | 01:36 PM
poison's Avatar
If your car is sitting idle for 5 to 10 minutes, the radiator fan is supposed to turn on to suck in cold air to cool off the radiator.
Sounds to me the cooling fan is not turning on. What you need to do is to make sure the fan is working properly. Simply hot wire the fan by sticking a wire from the positive wire on the fan to the battery and see if it turns on.
Also make sure the other wire on the fan harness is grounded properly. If it does NOT turn on, you will need to replace the fan. If it does turn on, then the coolant temp switch in the thermostat housing is bad and not sending the signal to the ECU to turn on the fan switch.
HTH.
Old Apr 17, 2003 | 04:41 PM
slomofo's Avatar
GDD Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turkcivic &raquo;</TD></TR><TR><TD CLASS="quote">wus up guys. when my car is not moving and the engine is on for about 5 to 10 min sometimes my engine overheats when i start to drive it goes back to the normal temp. I hve a 2000 honda civic si do any of you know why it is doing this.</TD></TR></TABLE>
It's probably your coolant temp sensor located under the distributor. I had that problem three times. On two of the occasions, my temperature went 25% higher as soon as I turned the heater ON.
chrisalvar
Jan 29, 2012 05:15 PM
408maro
25
Oct 19, 2010 06:42 PM
biker9075
May 31, 2008 03:35 PM
Notpretty
Jan 31, 2008 10:24 PM
mike93eh
Mar 26, 2005 03:04 PM
