D series block question...
Old Apr 16, 2003 | 11:00 AM
CimorelliCRX's Avatar
Default D series block question...
I have a simple question on blocks. I just need a block, my block has a stripped bolt hole in it, z6, and i was wondering if I get any d series block(except 88-89 integra), will everything from teh z6 bolt right in? I am planning on doing a complete rebuild, all z6(ZC pistons), z6 oil pump, if i have to, a6 water pump, but you get what im saying. Will it work right? Like everything bolt right in? Or do I need a Z6 block to do this too?
Old Apr 16, 2003 | 11:13 AM
coos's Avatar
everything should go over no problem..
Old Apr 16, 2003 | 12:11 PM
joshwhe's Avatar
Default Re: D series block question... (CimorelliCRX)
i would stay with the d16 series .. some d15's have a different bottom end build i do belive.
Old Apr 16, 2003 | 12:14 PM
Blue_Si03's Avatar
You can use a D15B2 bottom end and slap on the Z6 head but that'll yield high compression.
Old Apr 16, 2003 | 06:56 PM
Default Re: (CRXracer89)
Well i just need a bare block. I dont need any internals. Im gonna use all z6 internals except zc pistons.. Z6 head. My main question was are the blocks all the same, height wise, bore, etc.
Old Apr 17, 2003 | 05:21 AM
virginia_dude's Avatar
wouldn't it be easier just to get the stripped hole helicoiled or welded and rethreaded. Assuming this was the source of your problem. Just an idea. unless you are going to get the used block for free.
Old Apr 17, 2003 | 08:09 AM
Default Re: D series block question... (virginia_dude)
Well it was tried to be done, and the hole was drilled all the way THROUGH the block, so now water leaks out. Is there a way a machine shop could fix that, cause if they can redo the aluminum there then i would do that.
whereiscarmensandiego
Oct 26, 2008 08:43 PM
sanegb16
Feb 27, 2008 06:50 AM
Prudz_lude
41
Jan 22, 2008 01:36 PM
Caveman74
Apr 15, 2004 01:18 PM
