d series block question
bought a d16z6 head. I plan on turboing it but i want to drop some new pistons, and rods in a spare block. Which block should i be looking for? My friend is telling me d16y7 is obd2 my head is obd1 so it won't work. which block should i be looking for?
Re: d series block question (Prudz_lude)
my friend had a boosted a6 in his CRX, it ran pretty good until he threw a rod...
build yours right and you shouldnt have any problems
IMO id just spend the time looking for a z6 block
no, z6 is the strongest of the d series thats compatible with that head. the y7 and y8 block will make ignition timing off and the a6 block will work but will raise compression and is weaker than the z6. and dont even think about the 1.5 blocks
Re: d series block question (boosted92hatch)
Ok guys, i think i need to clarify something. I don't care how strong the blocks are stock. They will all support 300whp if i drop some forged internals in them. I just need to know which block i can use for my z6 head without running into issues when i swap it into my 92 VX hatch. The VX is economy vtec and obd1. this is my issue. Please try and explain this to me. I am extremely new to civics. I have been dealing with preludes for the last 3 years until now.
also thank you nix94delsol for the link to that site
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude »</TD></TR><TR><TD CLASS="quote">
also thank you nix94delsol for the link to that site </TD></TR></TABLE>
No prob, the guys on turbo d are about as chill as everyone in the Del sol forum, theyll take care of you
your BEST bet is to find a z6 bottom end as well..unless you want to go minime...
if you do then
https://honda-tech.com/zerothread?id=554053
thats your friend^^
if you do then
thats your friend^^
Re: d series block question (nix94delsol)
yah i read that mini me thread. Its funny, its what is making me buy a new block. I have a vx and it says don't waste your time because of low compression. However, wouldn't that be a good thing with a turbo? If i turbo'd my vx block with the z6 head i would just aim for 180whp so its nice, safe, and conservative.
I have been told the wiring is very simple since my vx already has vtec wired in and has a vtec soloniod. I have a z6 wiring harness, intake manifold, injector, fuel rail assembly that was given to me. Is there only one engine wiring harness? My prelude had 2 engine harnesses.
My main concern is the wiring and ecu crap. If i get a z6 block i will have to convert from obd1 to obd2. I have no clue what ecu i need, and no clue what wiring harness i need, or even how many pieces there are to the harness
u do what your freind says and i will 100% gaurentee your car runs like ****. the y7 block is compatible with the y8 head but if u put the z6 head on that block at idle, the car will be fireing 2 degrees out of timing. as u accelerate the timing will get even worse. u can google and research it all u want. i have done this and i thought i had the belt wrong and even tried to use an adjustable cam gear to make up the 2 degrees. IT DOES NOT WORK.my car ran like crap and i had perfect compression so it wasnt the motor. it would misfire and all kinds of other timing issues. DO NOT DO THIS!! find a z6 block, and yes u should care how strong the block is, rods and pistons dont change the blocks strenght. it changes the blocks internal parts strenght. why do u think they make dart blocks.
thanks boosted92hatch. I had no clue they made dart blocks honestly lol. i'll look for a z6 assembly i guess. This means i have to convert from obd1 to obd2 correct? Does a hondata s300 still work with obd2?
why would u want to do anything obd2? d16z6 is obd1. if u have a 92/95 civic, just put the z6 in there, u can actually plug the ex harness right into the existing harnesses and remove your vx harness, plug a p28 ecu in your car and that is all u need to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude »</TD></TR><TR><TD CLASS="quote">really? Well then that makes me alot happier. Which ecu do i need to buy for the z6? p08? someone told me that i think.</TD></TR></TABLE>
p28
p28
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude »</TD></TR><TR><TD CLASS="quote">ok thank you. You guys have cleared up alot. Anybody know someone selling a z6 block and a p28?</TD></TR></TABLE>
id sell you them!
but your on the other side of the US
id sell you them!
