About to order custom pistons - could someone double check me?
Old Apr 16, 2003 | 10:27 AM
dennis's Avatar
Default About to order custom pistons - could someone double check me?
Hey all, about to order custom pistons for my f22b2. I'm using Eagle rods (prelude VTEC) which are 1.5mm longer than stock (hence the need for custom pistons). Stock cylinders. Probably going to use Ross and go through flatlanderracing.com - open to suggestions though.
The main thing I have to get right is the deck height, they should be able to calculate the c/r from there. What's the average thickness of a honda head gasket?
Thanks all...
Specs for getting pistons made: ( I just pasted a bunch of info from my text file I've been writing to)
Leaning towards 9.0 - 9.5:1 c/r
Engine size = 2156.31cc
Bore: 85mm or 3.346 (actual = 3.350)
Target bore: Maybe shoot for 85.75 (3.376), which is about .026 over
Stroke: 95mm (3.740)
Half of stroke = 47.5mm
Deck Height: 220.015mm or 8.662
Head: 50.6cc
Rod length (vtec rods): 143mm or 5.63 (stock = 5.580 accord rods)
1/2 stroke + rod length = 190.5mm
working comp height = deck height - (1/2 stroke + rod length) = 29.515mm (1.1806)
Possible turbo:
T3/T04e-50
T3/T04e-57 .64a/r (leaning towards)
T3/60-1
Old Apr 16, 2003 | 11:02 AM
dennis's Avatar
Default Re: About to order custom pistons - could someone double check me? (dennis)
c'mon guys, could use a little reassurance/or alternative suggestions before plopping down big money.
Old Apr 16, 2003 | 11:10 AM
Kwuaymaikrup's Avatar
I would think that all you have to do is have the wristpin moved up in the piston to compensate the longer rod? The dome will be the same. They should have no problem making these for you. Just tell them your desired compression ratio and your rod length and you should be ok. HTH Just my .02
-Ryan
Old Apr 16, 2003 | 11:12 AM
b18bturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennis &raquo;</TD></TR><TR><TD CLASS="quote">Hey all, about to order custom pistons for my f22b2. I'm using Eagle rods (prelude VTEC) which are 1.5mm longer than stock (hence the need for custom pistons). Stock cylinders. Probably going to use Ross and go through flatlanderracing.com - open to suggestions though.
Thanks all...
Head: 50.6cc
Possible turbo:
T3/T04e-50
T3/60-1
The gasket should be std .028 thousand gasket which is most factory honda.
Old Apr 16, 2003 | 11:23 AM
dennis's Avatar
Default Re: About to order custom pistons - could someone double check me? (Kwuaymaikrup)
yeah, that's what I figured too, but seeing that the f22b2 isn't as popular as b and d's, I wasn't sure if they had all the oem specs. Thanks guys - good info
joiv21
Jan 15, 2013 01:58 AM
SiR99
Sep 1, 2006 09:17 PM
del_slow420
Jul 27, 2006 08:58 AM
SOHCD16y8
May 20, 2005 10:34 PM
x2gold
Jun 1, 2003 04:08 PM
