Is an AVCR needed with AEM EMS? Do they work in conjunction?
Old Apr 16, 2003 | 09:11 AM
Spoold_R's Avatar
New User
Default Is an AVCR needed with AEM EMS? Do they work in conjunction?
I plan to run an AEM EMS, do I need an AVCR to control boost? Can the AVCR control the boost through the EMS. Someone gimme the scoop.
Old Apr 16, 2003 | 09:19 AM
Daniel's Avatar
Default Re: Is an AVCR needed with AEM EMS? Do they work in conjunction? (RiTiCuLe)
I believe the EMS has its own built in boost controller. go to aempower.com to see the specs on it.
Old Apr 16, 2003 | 09:45 AM
Mase's Avatar
Default Re: Is an AVCR needed with AEM EMS? Do they work in conjunction? (Daniel)
the ems doesnt have a boost controller, but it comes w/ a boost control feature, when used in conjunction w/ a boost control solenoid, it works damn good
basically all you need is a $25 dollar part and the ems to control boost
Old Apr 16, 2003 | 04:25 PM
tSuperbike69's Avatar
Default Re: Is an AVCR needed with AEM EMS? Do they work in conjunction? (Mase)
The ems will control boost just fine dont waste the money on an avcr just pick up the gm boost sol or the apexi boost sol the gm one is about $35 with the pigtail and the apexi one is about $130 check out http://www.horsepowerfreaks.com for the part
The Jacko
Jul 31, 2006 06:12 AM
sander
May 18, 2006 12:56 AM
siblues
Aug 7, 2005 05:47 PM
Aug 19, 2002 06:50 PM
PyroVTEC
Jun 7, 2002 11:51 AM
