Problems after installing Insulated IM Gasket
Old Apr 15, 2003 | 10:40 PM
1 speedstar's Avatar
Default Problems after installing Insulated IM Gasket
I'm not sure if anyone else had this problem before, but after installing a Insulated Intake Manifold Gasket I got a code for the IAC (code 14). I'm getting a wierd idle. For instance, when cruising in neutral coming to a stop, my idle will be at 1.5k. Then when I come to a stop, it jumps from 1.5k to 1k a couple of times then drops down to about 1k and sits there. Sometimes is stays at 1.5k.
I'm using the AN-R Gasket, and I've checked the IAC and everything seems to be in place (i even tried switching around some plugs to see if i plugged in the wrong plug). I've retightened most of the Intake Manifold bolts, I say most because some were harder to reach.
Has anyone had a problem like this after installing this piece? Could the wierd idle IAC problem be caused by loose bolts on the Intake Manifold creating a air leak? Any info is greatly appreciated.
Old Apr 16, 2003 | 09:18 AM
Default Re: Problems after installing Insulated IM Gasket (1 speedstar)
ttt
Old Apr 16, 2003 | 09:53 AM
shaun23's Avatar
it sounds like you don't have a fresh source of coolant going to the IAC. Check those lines and make sure they are not kinked or anything like that...
Old Apr 16, 2003 | 04:51 PM
Default Re: Problems after installing Insulated IM Gasket (shaun23)
checked the lines, no kinks and its full of coolant, ttt
Old Apr 16, 2003 | 05:25 PM
b20guy's Avatar
Try checking for vacuum leaks. You could wait until the up n down idling occurs, then spray carb cleaner around the intake manifold in short bursts, around isolated areas. See if you notice a change in the idle. If you do, double check that area for vacuum leaks.
phoshyzzle
Sep 24, 2008 08:06 PM
vtec128
Jul 25, 2008 03:22 AM
aalb1
10
Apr 19, 2005 07:32 AM
98itr0448
Jul 10, 2004 03:17 PM
