crx b18c1 swap wont start no spark
Old Apr 15, 2003 | 08:44 PM
DOHCarp's Avatar
Default crx b18c1 swap wont start no spark
I just finished my B18C1 OBD2 swap into my 1988 crx si
I am not getting any spark
I am useing a OBD0 TO OBD1 harness from blown hatch for the ecu
I rewired my Dizzy like this... from the engine harness
Non-OBD sensor (EF)-> (EF)Non-OBD pin ->(EF) Non-OBD Wire color ->OBDII sensor ->OBDII pin ->OBDII Wire color
CYP G c2 blue/yel CYP M c14 white
CYP P c1 blue/grn CYP P c4 orn
CNK G b12 white(small) CKP M c12 blue/yel
CNK P b10 orn CKP P c2 blue/grn
TDC G c4 wh/blue TDC M c13 wh/blue
TDC P c3 orn/blue TDC P c3 orn/blue
non-OBD Blue goes to OBDIIblue (tach)
non-OBD Black/yellow goes to OBDII black/yellow
non-OBD (large) white goes to OBDII yellow/grn
and no spark so did I wire something wrong?
I am useing an OBD2 dizzy
I am getting power to the coil but no spark at all
can someone point me in the right direction?
thanks
Old Apr 16, 2003 | 04:39 AM
DOHCarp's Avatar
Default Re: crx b18c1 swap wont start no spark (DOHCarp)
anyone?
Old Apr 16, 2003 | 08:43 AM
red civic standard's Avatar
I wired my civic to OBD1 using an OBD2 distributor.
All of the dizzy wire colors matched up except the two OBD0 white wires. I guessed on those two and must have got it right.
It appears that you maybe haven't matched up your ORANGE wire. Not sure though.
HTH
Old Apr 16, 2003 | 08:44 AM
Default Re: crx b18c1 swap wont start no spark (red civic standard)
try switching the white wires first.
then mess with the orange wire.
Old Apr 16, 2003 | 09:16 PM
DOHCarp's Avatar
tried everything even another coil, but no spark still.
any more ideas?
thanks
Old Apr 16, 2003 | 11:53 PM
91bizzerhatch's Avatar
did you wire your map sensor right
Old Apr 17, 2003 | 04:36 AM
Default Re: crx b18c1 swap wont start no spark (91bizzerhatch)
check your grounds.
one going from the frame to the tranny and one from the frame to the valve cover.
Old Apr 17, 2003 | 05:48 AM
DOHCarp's Avatar
I know where the grounds are I hooked them up
and I dont need to wire up my map sensor, I just used the one on the firewall and hooked it to vacume.
I have power to the coil but no pulse?
but I am getting an injector pulse.
Old Apr 17, 2003 | 06:45 AM
type Gendy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard &raquo;</TD></TR><TR><TD CLASS="quote">check your grounds.
one going from the frame to the tranny and one from the frame to the valve cover.</TD></TR></TABLE>
I had a similar problem...... There is a third, most important ground, however. It bolts on to your thermostat housing.... IT is a key ground, because it grounds out like everything, motor, ecu... There are about 5-6 wires in that part of the harness...CHECK THAT. It is very easy to miss.
Old Apr 17, 2003 | 07:17 AM
Shawn C's Avatar
In The Garage
Default Re: crx b18c1 swap wont start no spark (sick hatchem)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sick hatchem &raquo;</TD></TR><TR><TD CLASS="quote">
I had a similar problem...... There is a third, most important ground, however. It bolts on to your thermostat housing.... IT is a key ground, because it grounds out like everything, motor, ecu... There are about 5-6 wires in that part of the harness...CHECK THAT. It is very easy to miss.</TD></TR></TABLE>
i'm glad i wasn't the only one who **** his pants when the new engine wouldn't start. yes, the ecu ground is very important. is your fuel pump coming on for a sec when you click the key on? if it isnt, then your ecu isn't getting power/ground. don't just narrow it down to the dizzy, assumption could be your problem here.
Old Apr 17, 2003 | 09:02 AM
DOHCarp's Avatar
Default Re: crx b18c1 swap wont start no spark (22lbGS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22lbGS-R &raquo;</TD></TR><TR><TD CLASS="quote">
i'm glad i wasn't the only one who **** his pants when the new engine wouldn't start. yes, the ecu ground is very important. is your fuel pump coming on for a sec when you click the key on? if it isnt, then your ecu isn't getting power/ground. don't just narrow it down to the dizzy, assumption could be your problem here.</TD></TR></TABLE>
I am getting fuel and Ii do have power to the coil, but still no spark. I am going to try a new igniter tonight, a wire was hooked up wrong on the igniter when I took it apart, so I am hopeing that killed the igniter.
also i do have all the ecu grounds taken care of.
thanks
Old Apr 18, 2003 | 07:36 PM
DOHCarp's Avatar
still no spark???
95f22a1
22
Feb 2, 2009 10:12 AM
DOHCarp
Sep 19, 2006 05:24 PM
3s0n3
Apr 4, 2006 02:07 PM
tvstealer
Mar 14, 2006 07:07 PM
DOHCarp
Apr 18, 2003 07:36 PM
