Idle Air Control System or TPS Sensor?
Old Apr 15, 2003 | 05:20 PM
civicboisi's Avatar
Default Idle Air Control System or TPS Sensor?
Guys-
My car started acting up after i installed a junkyard IAC thingy. I thought since my car idles from 1000-2000 rpms, it might have been a bad IAC. So me and my guy went to a junkyard and pulled one off. Since the new replacement, without a gasket, my car throws a CEL. It reads 7 then a long light then 7 again. Is this 14? Or 7? I replaced my TPS sensor too (i actually replaced the whole TB). It throws it (CEL) after my speedo doesn't work. When i first drive, and my speedos out, the CEL will come on. But if i start the car and drive, speedo working fine, no check engine light. WTF? Help please
Thanks.
Old Apr 15, 2003 | 09:48 PM
civicboisi's Avatar
Default Re: Idle Air Control System or TPS Sensor? (civicboisi)
up
anyone?
Old Apr 16, 2003 | 03:12 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicboisi &raquo;</TD></TR><TR><TD CLASS="quote"> a long light then 7 again. </TD></TR></TABLE>
Code 17 = VSS
Old Apr 16, 2003 | 06:03 AM
JiggaFan's Avatar
That bad idle could have been the fast idle thermo control valve. See my post on how to check it in my '97 Accord.
I tried the junkyard IAC thing too. Fortunately, it didn't fukc my car up even more. But it didn't fix my idling problem, either.
Old Apr 16, 2003 | 09:00 PM
civicboisi's Avatar
Default Re: Idle Air Control System or TPS Sensor? (TurboD16Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboD16Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Code 17 = VSS</TD></TR></TABLE>
thanks for the correct reading. I believe it might be my VSS because of the way its been acting up. Problem is, it'll work fine, then go out all of a sudden... bad connection?
Old Apr 16, 2003 | 09:01 PM
civicboisi's Avatar
Default Re: (JiggaFan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JiggaFan &raquo;</TD></TR><TR><TD CLASS="quote">That bad idle could have been the fast idle thermo control valve. See my post on how to check it in my '97 Accord.
I tried the junkyard IAC thing too. Fortunately, it didn't fukc my car up even more. But it didn't fix my idling problem, either.</TD></TR></TABLE>
I've looked into your post too...lots of good info...i'll look into that too!
Shade93
Aug 27, 2010 06:29 PM
bennyv613
Jun 16, 2009 06:18 PM
bLu92bUbbLe
Sep 26, 2008 01:57 PM
jdmmachine
Mar 20, 2007 07:08 PM
eghatch909
13
Feb 21, 2007 11:47 AM
