Info On A B20 VTEC HELP!
Old Apr 15, 2003 | 04:31 PM
88B20CRX's Avatar
Default Info On A B20 VTEC HELP!
has anybody out there done a CR-VTEC swap. My timing belt wont fit on my new motor. i had to put a B16 water pump on because the stock B20 wouldnt be able to handle the high RPM's. now the CR-V nor B16 belt will fit. what should i do or what kind of combinations shoud i use. thanks.
Old Apr 15, 2003 | 04:34 PM
mmuller's Avatar
Mad Scientist
Default Re: Info On A B20 VTEC HELP! (88B20CRX)
U gonna have to use a gsr timming belt
Old Apr 15, 2003 | 05:40 PM
88B20CRX's Avatar
Is that the only thing that will help. nothing else?
Old Apr 15, 2003 | 05:53 PM
lazy bum shaughn's Avatar
Default Re: (88B20CRX)
I would get the GSR timing belt, water pump, and oil pump. You have to use the same water pump as the timing belt.
Old Apr 15, 2003 | 06:41 PM
SoulDigger's Avatar
Default Re: (lazy bum shaughn)
I agree. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazy bum shaughn &raquo;</TD></TR><TR><TD CLASS="quote">I would get the GSR timing belt, water pump, and oil pump. You have to use the same water pump as the timing belt.</TD></TR></TABLE>
I used all these on my B20/VTEC in my Integra with no problems.[
Old Apr 17, 2003 | 04:40 PM
88B20CRX's Avatar
what year GSR should i use?
Old Apr 17, 2003 | 05:23 PM
NAsohcNovtec's Avatar
94-95 GSr would be fine
ekturbohatch22
May 11, 2007 07:25 PM
Dr.Octagon
Jun 12, 2006 07:42 AM
Scorchin Civic
Mar 1, 2006 05:25 PM
1SickHb
Oct 4, 2005 09:00 AM
hatchii
Jun 9, 2003 10:19 PM
