Check Engine Light???
Old Apr 15, 2003 | 10:48 AM
b16_madman's Avatar
Default Check Engine Light???
Yesterday I was on a 3 and 1/2 hr trip and my check engine light came on for the first time. So I pulled over and checked the engine. It wasn't running bad, leaking anything, or any other weird noises like that. I checked the oil and it was a little low but not past the lower dot on the dipstick. Is this what made the light come on?
I couldn't check the ecu light b/c the ecu is upside down. It drove the same, and if I turned the car off and back on it would go away for roughly 30 min.
I stopped at a gas station dumped a quart of oil in it, but that didn't help. I think that's why it came on, but the ecu was never reset, so I unplugged the ecu's fuse and waited about 5 min. and put it back in and it hasn't come on yet.
I hope that's why the light came on. I guess the highway rpm @ about 5k the whole way burned the oil going in and out of vtec did it. Anyone else have that happen before???
Old Apr 15, 2003 | 10:54 AM
Malgerus's Avatar
Default Re: Check Engine Light??? (B16_madman)
As long as the oil wasn't dangerously low, then it wouldn't cause a check engine light. First step is to figure out what the code is... could be 02 sensors, coolant temp sensor, VTEC solenoid, who knows. Figure out what the code is first. I can almost guarantee that the light wasn't caused by eating a bit of oil.
Old Apr 15, 2003 | 10:57 AM
b16_madman's Avatar
Default Re: Check Engine Light??? (Mr. S)
Crap. I'll check and see if the ecu is blinking something this afternoon. It might have of been lower than it should. This is the first check engine light happening ever with this motor.
Old Apr 15, 2003 | 11:05 AM
Malgerus's Avatar
Well, try pulling the hazard fuse and resetting it after you read the code. Somtimes it'll go away. OBD-O B16 ECU's are very very finicky.
Old Apr 15, 2003 | 11:27 AM
RCautoworks's Avatar
Sometimes the 02 sensor code will just pop up. First check what code you had, then reset the ecu.
Old Apr 15, 2003 | 11:33 AM
Buzz Kill's Avatar
Default Re: Check Engine Light??? (90blackcrx)
I would bet that it is the O2 sensor.
It will either be flashing one or two.
Pull the hazard fuse (10 am in the box on top of the Passenger side strut tower). Keep it out for about 10 seconds.
If it comes back, you might need to change the sensor(s)
Old Apr 16, 2003 | 10:59 AM
b16_madman's Avatar
Default Re: Check Engine Light??? (Buzz Kill)
ok well it hasn't came back on yet after a day or so, so i guess i'm ok. (knock on wood)
Old Apr 16, 2003 | 01:18 PM
onetrueshyguy's Avatar
could b ur dizzy
check cap n rotor for red dust..
Old Apr 16, 2003 | 01:20 PM
Outsane's Avatar
My sugestion.. turn over your ECU and next time check the code...
Old Apr 16, 2003 | 02:17 PM
yellow_si's Avatar
the 02 censor
Old Apr 16, 2003 | 02:31 PM
senbei's Avatar
sup guys?
i drive a 90civic hb...the version below dx..and my check engine light has been coming on also? ...this happens when i get near 60-65 i was thinking it was my rpm's getting to high..but i have some holes in my exhaust..so do any of you guys have an idea what might be wrong or how i could figure it out?
thanks,
steven
Old Apr 16, 2003 | 03:11 PM
SteveeeO's Avatar
Default Re: (senbei)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by senbei &raquo;</TD></TR><TR><TD CLASS="quote">sup guys?
thanks,
steven</TD></TR></TABLE>
also have this similar problem
Old Apr 17, 2003 | 05:39 AM
b16_madman's Avatar
Default Re: (SteveeeO)
still no light. ive been driving it the same, have hit rpm limiter, and speed limmiter just to be sure its not that stuff.
tacchan
25
Apr 5, 2010 06:37 AM
torqueless
Acura TL, RL & ZDX
Mar 31, 2005 04:02 PM
EuN_TeK
May 27, 2003 01:16 PM
JohnnyM
Feb 20, 2002 03:50 PM
Muckman
Oct 4, 2001 06:23 AM
