Check Engine Light...
Old May 27, 2003 | 09:16 AM
EuN_TeK's Avatar
Default Check Engine Light...
Does the check engine light come on if you are low on oil?
My car only has 19500 miles and the check engine light came on and I am getting paranoid right now...
The thing is... even if the light comes on if oil is low... I don't understand how the oil is low... I haven't driven the car hard for a while and the last time I checked about a 1000miles ago... it was right in between the two lines...
Someone please help me out...
Old May 27, 2003 | 09:19 AM
B2FiNiTY's Avatar
Default Re: Check Engine Light... (EuN_TeK)
What is the oil level now?
Do you have any mods?
Old May 27, 2003 | 09:20 AM
EuN_TeK's Avatar
Default Re: Check Engine Light... (B2FiNiTY)
AEM CAI is the only thing I have on my car... And the oil level is right below the bottom line...
About the engine check light though... I'm freaking out man... heh...
Does the light come on if you are low on oil?
Old May 27, 2003 | 09:29 AM
B2FiNiTY's Avatar
Just fill up your oil and reset it. You should watch your oil very often because ITR's tend to drink it out of nowhere sometimes.
Old May 27, 2003 | 09:31 AM
EuN_TeK's Avatar
Is there any reason for me to worry about the light?
Should I take it to a dealer and get it checked up?
RaVAGE00's Avatar
New User
the oil light should come on if you are low on oil...
I would reset the ECU.... if the light comes on again, read the code to see what's wrong.... if the car is under warranty, just let the dealer worry about it...
Old May 27, 2003 | 09:40 AM
EuN_TeK's Avatar
Default Re: Check Engine Light... (RaVAGE00)
ok... I guess I don't have to freak out... the thing is... my car is still under warranty... but the closest acura dealership is 130 miles away... there are honda dealerships though... maybe I can set up something...
Old May 27, 2003 | 09:48 AM
nightrider's Avatar
first, fill your oil. then reset your ecu and if the check engine light comes on again, you need to find out what's throwing the code.
http://www.c-speedracing.com/faq/03.php good luck!
Old May 27, 2003 | 09:49 AM
tonyxcom's Avatar
Why dont you just read the code and figure out what the ECU is trying to tell you and go from there.
Then add a quart of oil.
You drive an Integra, not a rocket. You dont have to be a scientist to correctly operate it.
Old May 27, 2003 | 12:20 PM
RaVAGE00's Avatar
New User
Default Re: Check Engine Light... (tonyXcom)
not sure oil is the issue... since it was mentioned that it is only slighlty low.... ahhhh... just get it checked from the dealer....
Old May 27, 2003 | 12:58 PM
Nizzy's Avatar
I heard the check engine light comes on when you need to get a new oxygen sensor.
Old May 27, 2003 | 01:01 PM
tonyxcom's Avatar
Default Re: Check Engine Light... (Nizzy)
LOL, there are about 100 things that can cause the CEL to turn on.
Old May 27, 2003 | 01:03 PM
acuracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nizzy &raquo;</TD></TR><TR><TD CLASS="quote">I heard the check engine light comes on when you need to get a new oxygen sensor. </TD></TR></TABLE>
Interesting. Mine came on when my wheel fell off on the freeway.
Old May 27, 2003 | 01:16 PM
aaj23's Avatar
Default Re: Check Engine Light... (acuracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuracing &raquo;</TD></TR><TR><TD CLASS="quote">
Interesting. Mine came on when my wheel fell off on the freeway.</TD></TR></TABLE>
Hahahahahahahaha....sorry to laugh at your misfortune, but that's great timing, it went on just after.....hahhahahahha....what a great warning system.
Check engine light can be caused by something like 300 different things, and although there are only like a hundred codes, many can be one or a combination of things.
Easiest way to figure out the problem, is just stick a paperclip in the jumper and see how many times your CEL blinks, remember, it may read out more than one code, so long blinks are the first number, and short blinks are the second....
ie.. blink.......blink.........blink..blink..blink would be code 23, not sure what that is, but someone already posted a link for all the CEL codes. The jumper is located above your ECU usually in a little green rubber thing, it's the only two prong open connector in that area...if you look, you can't miss it....
Once you check, pull your hazard fuse under the hood, that will reset the ECU without having to pull your battery or unpluging your ecu.
By the way, on a side note, in order for your CEL to come on from low oil level, you'd really need to be low, to the point where your vtec either wouldn't work or would be sputtering....so that's probably not the problem...
Good luck,
Aj
Nukin
Apr 29, 2018 09:36 PM
slayerfromhell212
Jan 1, 2007 02:26 AM
shraz
13
Jun 8, 2006 08:11 PM
mugenhatchie
Jan 30, 2006 06:50 PM
Sohc Driver
Jul 9, 2003 11:38 AM
