Is it possible to fit a B18C Quaif LSD into an H22A Gearbox (with some changes i'm guessing)
Does anyone know whats involved in making a B18C quaif LSD Fit into a H22A Gearbox if at all possible?
The quaif needs new gears made for ones that are broken, and i'm wondering if its possible to get some other parts machined or another gear made that will make it fit into a H22A gearbox while the machinist is at it?
Or is it just not worth the hassel.....
(Also the H22A is turbo charged, so would an original H22A quaifLSD be stronger than a B18C one?)
Not worth the hassle. Best thing (always!) is to get the correct part for your application. For some reason, many dedicated transmission shop cannot seem to get these trannies right. Make sure your trans is at a reputable shop that has A LOT of experience with Hondas and that the diff is SHIMMED right and the clearances are correct. If your quaife has broken gears, throw it away. It is always more expensive to rebuild, and the margin for error is a lot bigger.
Good luck.
Good luck.
