EP3 makes loud pop...
Hey guys,
I have an hks catback and just installed the aem cai a few days ago....
Im driving home from class and i gave it some after some railroad tracks to get up to speed again, and i heard a backfire pop like noise come from up front. I reached down and check the filter and its seems fine, everything seems to be hooked up still okay, any idea what it was??
Can you backfire out your intake? my friend said this was possible
I just want to make sure my car is normal and nothing should be checked before i keep driving it. this all may sound weird but i just want to be careful..
Any input guys?
Thanks!
Any input guys?
Thanks!
i was goin like 2 mph over those tracks, the reason why it happened was cuz i went fast to regain my speed after, and thanks todaCspec, i looked on epahtch.com and it seems that the reason may be cuz my car was not warmed up all the way yet, and it does seem to be a common CAI problem, but seems harmless as of now as far as anyone knows
ive had my CAI for almost a year now and i just heard that backfire noise a couple months ago and it happened twice total. hasn't happened since. i was cruising at a low rpm and suddenly gunned it, then POP. that is how it happened to me both times, car was fully warmed up also.
I have the POP without an aftermarket filter. I believe the POP comes from the ignition timing. It sounds like the exhaust is back firing. I also think this has something to do with the bogging under hard acceleration.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Migs »</TD></TR><TR><TD CLASS="quote">I have the POP without an aftermarket filter. I believe the POP comes from the ignition timing. It sounds like the exhaust is back firing. I also think this has something to do with the bogging under hard acceleration.</TD></TR></TABLE>
Did you guys reset your ECU after the mods?
From: With my POS D15B2, Whereever whenever, United States
it's normal, with an exhaust more air is going through and th epopping is because your engine is running rich.
It happens on almost every car with stock ecu
Yes, For a while I had a short ram on my EP3 and I have a Short ram on my Civic Lx with a B16A, I have also heard the pops coming from what it sounds like the intake. But soon Im putting AEM/CAI on my EP3
