endyn piston ring gap
Old Apr 14, 2003 | 04:59 PM
bretx0r's Avatar
Default endyn piston ring gap
I got my rings gapped and the guy who gapped them said that when he put them in the bore WITHOUT FILING them it was 0.015 which is out of endyn's specs for 81mm bore... what should i do?
Old Apr 14, 2003 | 07:28 PM
bretx0r's Avatar
Default Re: endyn piston ring gap (bretx0r)
12 views and no replies. tech section is ******* worthless
Old Apr 14, 2003 | 09:31 PM
riceboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bretx0r &raquo;</TD></TR><TR><TD CLASS="quote">what should i do?</TD></TR></TABLE>
call Larry.
Old Apr 15, 2003 | 03:23 AM
turbodsmpower's Avatar
Default Re: endyn piston ring gap (riceboy)
i would just buy new ones personally they should be around .012...015 is a little big just buy new rings there cheap enough i got mine from larry for like 75 bucks tell him what pistons your running and compression and how much youplan on pushing them
Old Apr 15, 2003 | 11:25 PM
bretx0r's Avatar
ttt
Old Apr 16, 2003 | 04:39 AM
torr's Avatar
if your positive that the rings are out of spec even before you file fit them, then why not just call larry and send it back, shipping them should only be like 7 bucks or send it c.o.d for 7 bucks and get your shipping money back, and get the right ones. i went threw 2 sets of je rings from race eng. before i got the right ones.
Old Apr 16, 2003 | 08:50 AM
bretx0r's Avatar
Default Re: endyn piston ring gap (torr)
hmm... must have been packed in the wrong box because it says 81mm ring set on the box... and the guy who did my honing couldnt possibly have taken that much material off with a hone because 0.011 and 0.012 spec is for 81.5mm and 87mm is the spec for 0.015 after filing .... does anybody know larry's phone ##... i forgot endyn's site address
Old Apr 16, 2003 | 08:53 AM
CHEETAH's Avatar
email staff@theoldone.com and let Josh or Larry know
greg
Old Apr 16, 2003 | 09:46 AM
mikikanazawa's Avatar
Did the rings go in square with the bore?
If they're crooked, the gap will appear to be large.
EJ8chu
23
Jul 13, 2012 06:15 PM
hondachris1994
Dec 29, 2008 07:59 AM
92civichbor
10
Aug 5, 2008 11:09 AM
drumminforev
Dec 11, 2006 05:38 PM
EKB18BPR3
Jul 10, 2004 04:17 PM
