Octane vs. Emissions
Old Apr 14, 2003 | 04:51 PM
toooslow's Avatar
Default Octane vs. Emissions
I just took my car to the refferee and passed both the visual and emissions test, i failed the functional due to my check light comming on because of my knock sensor at the end of the test. My question is "does octane effect emmissions?" I was just thinking of throwing a bottle of octane booster in my tank so i could take the test and wouldnt have to worry about the engine pinging. timing is already low at 15 TDC.
Old Apr 14, 2003 | 07:54 PM
Therumblingteg's Avatar
Default Re: Octane vs. Emissions (whiteinteg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 &raquo;</TD></TR><TR><TD CLASS="quote">I just took my car to the refferee and passed both the visual and emissions test, i failed the functional due to my check light comming on because of my knock sensor at the end of the test. My question is "does octane effect emmissions?" I was just thinking of throwing a bottle of octane booster in my tank so i could take the test and wouldnt have to worry about the engine pinging. timing is already low at 15 TDC.</TD></TR></TABLE>
Lower octan is actually better for smog because it buns better, and faster, this is what I was told by the smog guy.
Old Apr 14, 2003 | 09:09 PM
fleaf's Avatar
Default Re: Octane vs. Emissions (Therumblingteg)
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Therumblingteg &raquo;</TD></TR><TR><TD CLASS="quote">
Lower octan is actually better for smog because it buns better, and faster, this is what I was told by the smog guy.</TD></TR></TABLE>
lower octane levels also causes detonation and the knock sensor to ping which is his problem. But generally, higher octane gas does lower emissions since it burns cleaner.
Old Apr 14, 2003 | 09:24 PM
riceboy's Avatar
Default Re: Octane vs. Emissions (fleaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fleaf &raquo;</TD></TR><TR><TD CLASS="quote">.
lower octane levels also causes detonation and the knock sensor to ping which is his problem. But generally, higher octane gas does lower emissions since it burns cleaner.</TD></TR></TABLE>
higher octane gasoline burns slower not cleaner, the burn rate (or resistance to) is what deters detonation, and I doubt the smog guy is even gonna smog the car is he hears pinging. The quality (or cleanliness ) of the burn is dictated by how homogenous the mixture is.
Old Apr 14, 2003 | 09:33 PM
fleaf's Avatar
Default Re: Octane vs. Emissions (riceboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceboy &raquo;</TD></TR><TR><TD CLASS="quote">
higher octane gasoline burns slower not cleaner, the burn rate (or resistance to) is what deters detonation, and I doubt the smog guy is even gonna smog the car is he hears pinging. The quality (or cleanliness ) of the burn is dictated by how homogenous the mixture is.</TD></TR></TABLE>
thanks for clarifying. After reading your post, I don't know what the hell I was thinking when I posted mine.
Old Apr 15, 2003 | 08:51 AM
man if your car is pinging at 3000 rpm you have other things to worrry about instead of smog.
hatch_
10
Mar 2, 2007 03:46 PM
SOLO1racer
Jan 27, 2005 12:36 AM
sunlei
Dec 6, 2003 08:43 PM
capcon83
Aug 14, 2003 03:15 PM
Mark
Mar 17, 2003 08:02 PM
