b18b in EF - headers anyone???
I want to put an ebay header on it while I put it in(the B18B). I hear the cross member gets in the way, but oyu can make a header fit. Any input? And should I get a header for a b18a or b18b? thanks dudes.
generally thats the way its going to work...4-2-1 2 piece best fitment and easiest to install....4-2-1 1 piece there will be troubles but no real clearance issues once its in....4-1 is the biggest problem depending on your mounts you most likely will have to dent or cut your cross member to make it fit...plus they hang lower than stock so if you car is already lowered you are going to experience some scraping...my cars dropped about 1.5" in front and i'm just using my stock b18 headers and they scrape ever so often...
