Helms Manual Owners: Wiring diagram?'s
Wondering, is there a Helms Manual per model (CX/EX/HX) or is it per car (Civic/Integra/CRV)?
If per model can you guys scan your engine wiring diagrams for me and email them?
We (Honda-Tech) need a permanent place for these diagrams and I want to add them to the "D series" post.
Thanx.
EDIT:
Emailing them is fine.
Need 88-91 pinouts, sensors and colors.
Have 92-95 wiring sensors and colors. Need ECU pinouts though.
Have 96-00 ECU pinouts, need sensors and colors.
EXample:
pr3_a
A01 BRN INJ1 fuel injector control # 1
A02 BLK PG1 Ground
A03 RED INJ2 fuel injector control # 2
A04 BLK PG2 Ground
A05 LT BLU INJ3 fuel injector control # 3
A06 GRN purge cut-off solinoid valve
A07 YEL INJ4 fuel injector control # 4
A08 VTS VTEC solenoid
A09
A10 Pressure Regulator Cutoff Soleno
A11 BLU/YEL IACV from electronic air control valv
A12 GRN/BLK FLR1 fuel pump control
A13 YEL/BLK IGP1 power Input
A14 GRN/BLK FLR2 fuel pump control
A15 YEL/BLK IGP2 power Input
A16 BRN/BLK ground
A17
A18 BLK/RED ground
B01 WHT/GRN VBP Battery Backup
B02
B03 YEL ACC a/c compressor clutch relay cont
B04 FANC
B05 WHT/YEL VTM VTEC pressure switch
B06 GRN/ORN MIL check engine warning light
B07
B08 YEL/GRN ACS a/c on input
B09
B10 ORN CYP P crank sensor (1)
B11 Fuse Box
B12 WHT ? CYP M crank sensor (2)
B13 BLU/WHT starting input
B14 BLU ALT alternator output signal
B15 WHT ? ignition output signal
B16 YEL/RED VSS VSS
B17 WHT ? ignition output signal
B18
B19 KS Knock sensor
B20 BRN SCS ignition timing adjusting connec
C01 BLU/GRN CKP P CYL sensor (1)
C02 BLU/YEL CKP M CYL sensor (2)
C03 ORN/BLU TDC P TDC sensor (1)
C04 WHT/BLU TDC M TDC sensor (2)
C05 RED/YEL IAT intake air temperature sensor
C06 RED/WHT ? ECT coolant temperature sensor
C07 RED/BLU TPS throttle angle sensor
C08 O2S Dual O2 Sensor (JDM)
C09 RED/WHT ? PA atomosphere pressure sensor inpu
C10 GRN/WHT ? BKSW brake light switch
C11 GRN/WHT ? MIL ground
C12 GRN/WHT ? SG2 TPS GND
C13 YEL/WHT VCC1 TPS 5V
C14 SG1 MAP GND
C15 YEL/RED VCC2 MAP 5V
C16 WHT O2S oxygen sensor
Modified by Spade at 2:01 PM 4/15/2003
Thanx.EDIT:
EXample:
pr3_a
A02 BLK PG1 Ground
A04 BLK PG2 Ground
A09
A16 BRN/BLK ground
A17
A18 BLK/RED ground
B02
B04 FANC
B07
B09
B11 Fuse Box
B16 YEL/RED VSS VSS
B18
B19 KS Knock sensor
C14 SG1 MAP GND
Helm's manual's are specific to Model and Generation. ie. Civic 1988-1991, Civic 1992-1995, Civic 1996-2000, etc.
I have access to just about all of them. What is it that you need/want?
I can get you stuff on 92 Civics, all trims, right now. I have another one for 96-00 civics on loan to someone right now, but will have it in a while. What do you need specifically?
Hey can you guys give me wiring colors for a 94 gsr? I need wire colors for:
VTEC solenoid
VTEC oil pressure
Knock Sensor
Evap Purge Power
Evap Purge Power
Evap Purge Solenoid
Secondary Intake Solenoid(IWB)
VTEC solenoid
VTEC oil pressure
Knock Sensor
Evap Purge Power
Evap Purge Power
Evap Purge Solenoid
I have the helms manual for 96-00 civic but don't have a scanner. It would be easier to try and meet up with someone in orange county or where ever and photo copy what you need.
I need all engine wiring for the 88-00 Civics.
Specifically, the differences. Since I'm seeing issues with the Auto IACV's and the manuals, differences in injectors, and other things.
-Gabe
EDIT: What wires go from what sensor/injector/device to what connector on the ECU and the color of said wire.
EDIT: Better yet....what wires (color and sensor) go in what pin on the ECU for each generation.
Modified by Spade at 8:47 AM 4/15/2003
-Gabe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">
This could take me some time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RareSI »</TD></TR><TR><TD CLASS="quote">
This could take me some time.</TD></TR></TABLE>
I figured but, once it's done it's done.
slorex
Aug 31, 2005 09:42 AM
