HELP ME WITH MY WIRINGS
Hey guys,
I need help with wiring up my greddy e-manage ultimate to my stock JDM PR3 ecu. Trust me, i've taken a look at the manual already and can't figure how to correlate with the E-manage wirings. I'll list the PR3 pinouts and then the e-manage pin-outs and I hope you guys can help me with which wire basically goes where from PR3 to E-manage.
<U>PR3</U>
A01 BRN INJ1 fuel injector control # 1
A02 BLK PG1 Ground
A03 RED INJ2 fuel injector control # 2
A04 BLK PG2 Ground
A05 LT BLU INJ3 fuel injector control # 3
A06 GRN purge cut-off solinoid valve
A07 YEL INJ4 fuel injector control # 4
A08 VTS VTEC solenoid
A09
A10 Pressure Regulator Cutoff Soleno
A11 BLU/YEL IACV from electronic air control valv
A12 GRN/BLK FLR1 fuel pump control
A13 YEL/BLK IGP1 power Input
A14 GRN/BLK FLR2 fuel pump control
A15 YEL/BLK IGP2 power Input
A16 BRN/BLK Ground
A17
A18 BLK/RED Ground
B01 WHT/GRN VBP Battery Backup
B02
B03 YEL ACC a/c compressor clutch relay cont
B04 FANC
B05 WHT/YEL VTM VTEC pressure switch
B06 GRN/ORN MIL check engine warning light
B07
B08 YEL/GRN ACS a/c on input
B09
B10 ORN CYP P crank sensor (1)
B11 Fuse Box
B12 WHT ? CYP M crank sensor (2)
B13 BLU/WHT starting input
B14 BLU ALT alternator output signal
B15 WHT ? ignition output signal
B16 YEL/RED VSS VSS
B17 WHT ? ignition output signal
B18
B19 KS Knock sensor
B20 BRN SCS ignition timing adjusting connec
C01 BLU/GRN CKP P CYL sensor (1)
C02 BLU/YEL CKP M CYL sensor (2)
C03 ORN/BLU TDC P TDC sensor (1)
C04 WHT/BLU TDC M TDC sensor (2)
C05 RED/YEL IAT intake air temperature sensor
C06 RED/WHT ECT coolant temperature sensor
C07 RED/BLU TPS throttle angle sensor
C08 O2S Dual O2 Sensor (JDM)
C09 RED/WHT ? PA atomosphere pressure sensor inpu
C10 GRN/WHT ? BKSW brake light switch
C11 GRN/WHT ? MIL Ground
C12 GRN/WHT ? SG2 TPS GND
C13 YEL/WHT VCC1 TPS 5V
C14 SG1 MAP GND
C15 YEL/RED VCC2 MAP 5V
C16 WHT O2S oxygen sensor
<U>E-Manage Ultimate</U>
3- Ignition Input signal CH4
5- Ignition input signal CH1
8- Ignition output signal CH4
9- Ignition output signal CH3
10- Ignition input signal CH3
11- Ignition Output signal CH2
12- Ignition Output signal CH1
13- VTEC input
14- VTEC output
15- Airflow1 (voltage input)
16- Throttle Position Sensor input (C07??)
17- Injector Input Signal CH1 (A01)
18- Injector Input Signal CH2 (A03)
19- Injector Input Signal CH3 (A05)
20- Injector Input Signal CH4 (A07)
22-Airflow 1 (voltage output)
23- RPM input signal
24- ECU ground (A16 OR A18??)
25- ECU power (A13??)
30- Injector ground (sensor ground)
31- Analog (voltage) input
33- Crank Angle Signal Input (B10??)
34- Injector Output Signal CH1
35- Injector Output Signal CH2
36- Injector Output Signal CH3
37- Analog (voltage) output
39- Cam angle signal input
40- VSS signal output
41- VSS signal input (B16??)
42- Injector Output signal CH4
Hope you honda-tech'ers can help me with this asap, i need to get my car running coz its a sitting duck since the standalone fried up on me. Oh yeah, its a stock b16/b20vtec just fyi.
<U>PR3</U>
A02 BLK PG1 Ground
A04 BLK PG2 Ground
A09
A16 BRN/BLK Ground
A17
A18 BLK/RED Ground
B02
B04 FANC
B07
B09
B11 Fuse Box
B16 YEL/RED VSS VSS
B18
B19 KS Knock sensor
C14 SG1 MAP GND
13- VTEC input
14- VTEC output
Powered By Garrett
03-30-2008 08:44 AM
slorex
08-31-2005 09:42 AM
