Making own valve adjustment tool.... will this work? *pic*
Old Apr 14, 2003 | 07:56 AM
BrandonClaps's Avatar
New User
Default Making own valve adjustment tool.... will this work? *pic*
Would this work if i got a regular 10MM deep socket wrench, and just welded a pipe or wrench to the top of it so the top was still open for the screw driver? Would a deepsocket go down far enough on the nut?
Old Apr 14, 2003 | 07:58 AM
rated_r's Avatar
Default Re: Making own valve adjustment tool.... will this work? *pic* (BrandonClaps)
i cant see why not
Old Apr 14, 2003 | 08:03 AM
New User
Default Re: Making own valve adjustment tool.... will this work? *pic* (rated_r)
would it go down far enough? without the handle hitting something?
Old Apr 14, 2003 | 08:13 AM
98TypeR's Avatar
might be easier with an angled handle.
Old Apr 14, 2003 | 08:16 AM
New User
Default Re: Making own valve adjustment tool.... will this work? *pic* (98TypeR)
maybe like a 45 degree up?
ITR764's Avatar
yes, that will work. then just put the screw driver through the socket.
Old Apr 14, 2003 | 08:19 AM
New User
Default Re: Making own valve adjustment tool.... will this work? *pic* (ITR764)
with the angle or without it?
Old Apr 14, 2003 | 08:20 AM
.RJ's Avatar
.RJ
Take a 10mm box end wrench, use a torch and bend the end of it 90 degrees.
Old Apr 14, 2003 | 08:56 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrandonClaps &raquo;</TD></TR><TR><TD CLASS="quote">would it go down far enough? without the handle hitting something?</TD></TR></TABLE>
no, the socket part should be almost twice as long as the deep socket is.
I had a guy at work weld me up one of these and it is okay but I wish the deep socket part was 2 inches longer!
also you can just use a box end wrench and heat it up then bend it, like http://www.c-speedracing.com has in their pics
Old Apr 14, 2003 | 09:06 AM
TypeR 01 886's Avatar
Default Re: Making own valve adjustment tool.... will this work? *pic* (owen_the_soyboy)
That would be one hell of a DIY. I think I would invest the money into the real tool. But thats just me.
Old Apr 14, 2003 | 05:53 PM
New User
Default Re: Making own valve adjustment tool.... will this work? *pic* (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Take a 10mm box end wrench, use a torch and bend the end of it 90 degrees.</TD></TR></TABLE>
tried that, heated it up for like 4-5 mins, bent it and it snapped ;[ i was using a propane torch...
Old Apr 14, 2003 | 06:31 PM
SurferX's Avatar
I don't know see what the big deal with the DIY valve adjustment tool is. Sounds like too much of a pain when I got mine for $25 at Harbor Freight, and even comes with 3 other sizes you can Ebay off.
Old Apr 14, 2003 | 09:59 PM
New User
Default Re: Making own valve adjustment tool.... will this work? *pic* (SurferX)
cause they are a few months on backorder
Old Apr 14, 2003 | 10:26 PM
R_yd's Avatar
w/ the angle
Old Apr 14, 2003 | 10:29 PM
FerioVtec94's Avatar
with the angle it will work fine, thats what i used
Old Apr 21, 2003 | 06:19 AM
00accord's Avatar
Ok, how about a 10mm deep socket and a pair of vise grips. I know, pretty simplistic, but I bought so many specialty tools for my dodge pickup and I could duplicate most of them and save $$.
huge230
Feb 3, 2006 10:47 AM
fe519
Jul 3, 2003 07:03 AM
Pineapple Devil
Jun 30, 2003 11:12 AM
BrandonClaps
Apr 14, 2003 07:23 AM
speedymon
Jan 15, 2002 01:09 PM
