ball joint camber kit question - need help asap?!?
Old Apr 14, 2003 | 06:01 AM
nick.na's Avatar
Default ball joint camber kit question - need help asap?!?
Maybe I am a fool for asking this but I couldn't find it with a search. Anyone have a step by step for replacing the ball joint with a ball joint camber kit? pics would be great also....I have the kit but am struggling with the installation. I have never removed ball joints before even. Your help would be MUCH appreciated asap
I bought the kit used and there were no instructions with it btw
- I'm not a COMPLETE fool ha
won't make a ton of difference but 91 crx SI
Modified by amber-bling at 3:14 PM 4/14/2003
Old Apr 14, 2003 | 06:24 AM
TheHatchHog's Avatar
Default Re: ball joint camber kit question - need help asap?!? (amber-bling)
1 First you need to take the wheel off! 2 Then remove whole brake assembly. 3 Then you need to take out the cotter pin from the ball joint and the tie rod on each side. 4 Next Take the nuts off. Once the nuts are off you will need to use a pickle fork to split the strut fork away from the lower control arm. 5 You really have to pound that **** in until it pops,,, a hammer does just fine --sometimes they pop open easier if you pet the pickle fork in the side, and then pound it . 6 Once the Strut fork pops away , you then have to loosen 2 bolts on the camber, disconnect the top joint near the camber, switch it up, the put **** back together. THIS IS ALSO HOW YOU REMOVE AXLES FOR A B16a SWAP OR ANY SWAP. BUT ONLY STEPS 1-5! ANY more questions ask <<< you may have to adjust the camber if you haver one of those adjustable kits..... I hope this helped
Old Apr 14, 2003 | 07:01 AM
nick.na's Avatar
Default Re: ball joint camber kit question - need help asap?!? (civicciviccivic)
it isnt the whole upper a arm (*you know what part i mean haha??)replacement...just a sliding ball joint...I have changed axles but thanks for detailed info though
Modified by amber-bling at 6:03 PM 4/14/2003
Old Apr 14, 2003 | 08:04 AM
sorry dude, I thought you were replacing the actual camber.
Old Apr 14, 2003 | 10:30 AM
nick.na's Avatar
its alright....anyone?
Old Apr 14, 2003 | 10:37 AM
Outsane's Avatar
Here is a how to I started..but its not complete..
http://www.teamsdxracing.com/lee/how2/camber/
Old Apr 14, 2003 | 11:30 AM
90civichbsi's Avatar
Default Re: ball joint camber kit question - need help asap?!? (Outsane)
http://www.specprod.com/PROD_DIR/PROD_PASSCAR.html
go to that site, pick the car your installing it on and find the balljoint type that you have and it will have instructions with pictures
Old Apr 14, 2003 | 11:34 AM
nick.na's Avatar
thanks
slipstreamsi
Oct 5, 2005 04:10 PM
ilikemyaccord
Aug 29, 2003 02:48 PM
ilikemyaccord
Aug 29, 2003 01:25 PM
nick.na
Apr 14, 2003 11:42 AM
wildstallion
Feb 6, 2003 08:18 PM
