Engine swap Question: Need Advice
Old Apr 13, 2003 | 05:24 PM
SpoonN1's Avatar
Default Engine swap Question: Need Advice
I have a 00 dx hatch and I recently hydrolocked my d16y7... I'm thinking about replacing the engine with a d16y8... Just wondering what all you Honda-Tech guyz do to the new engine... Do you guyz rebuild that thing or do you guys just plug and play everything and drive away... I have found several y8 around here but there is one for way cheap and a friend of mine wants to sell me his y8 but the prob is it was previously supercharged do you guys recommend buying this engine?
Old Apr 13, 2003 | 05:40 PM
t0p_sh0tta's Avatar
Default Re: Engine swap Question: Need Advice (SpoonN1)
It all depends on your plans for the motor and your budget. If you find a stock Y8 with low mileage that is in good condition, I would change the timing belt, oil pump, and water pump and drop it in. If you feel like working, or have a less than perfect motor, you can do a stock rebuild/mild build up for a couple of hundred.
Old Apr 13, 2003 | 07:19 PM
SpoonN1's Avatar
Default Re: Engine swap Question: Need Advice (t0p_sh0tta)
Yeah I plan on keeping the y8 N/A... Thx for the reminder of the t belt, oil pump and water pump, i almost forgot... What about the previously boosted engine?
Old Apr 13, 2003 | 07:30 PM
t0p_sh0tta's Avatar
It depends on the mileage, I would probably rebuild. I'm sure he has beat on it.
Old Apr 13, 2003 | 10:08 PM
SpoonN1's Avatar
No doubt... But how bad do you think it can be if it was auto... I heard auto trannys don't shift @ redline... but then again you don't have to redline the engine to beat on it right?
Old Apr 13, 2003 | 10:23 PM
madhatch's Avatar
how much boost? how long did he run it,
check the tb for oil if it had residue,
think,
dohc,
ls motors a cheap and a good start.
or take the head get another y7 for 50 bucks and mini me!!! whoopie...
Old Apr 13, 2003 | 11:42 PM
SpoonN1's Avatar
Default Re: (madhatch)
I'll take your advice into consideration... Need to do a search on "mini-me" swap. Is it like LS-Vtec? Thx for the input.
crxsi1
12
Aug 1, 2013 12:32 PM
CivicxTree754
Nov 15, 2011 01:23 AM
Chris_Spires
Aug 13, 2009 10:33 AM
Red_ED8
Apr 14, 2008 06:03 AM
Swipe'd
Mar 22, 2007 09:56 AM
