Td05 18g little shaft play okay?
Old Apr 13, 2003 | 02:31 PM
roydogg's Avatar
Default Td05 18g little shaft play okay?
I bought a td05 18g with less than 1000 miles on it and a friend of mines check the turbine and it move back and forth just a little, barely noticeble. Will it be alright? It does spin freely though but he said that it might not last long. But he is still in school to become a tech, So is he telling the truth? If he is, how do I get it fixed and will it be better if I just upgraded it to a 20g? Any help will be very appreciated
Thanks in advance,
Roy
Old Apr 13, 2003 | 04:15 PM
Tinker219's Avatar
Default Re: Td05 18g little shaft play okay? (roydogg)
a little is ok. What you DONT want is side to side movement....
Old Apr 13, 2003 | 05:12 PM
roydogg's Avatar
Default Re: Td05 18g little shaft play okay? (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">a little is ok. What you DONT want is side to side movement....</TD></TR></TABLE>
You mean as long as it doesn't move more than a mm right? It barely moves though and doesn't push in and out so I assume it's okay.
Old Apr 13, 2003 | 05:35 PM
Aeka GSR's Avatar
New User
I had a little bit of shaft play on mine. After it was installed and full of oil the shaft play went completly away.
slo_ej8
Mar 19, 2008 08:27 PM
DC_RaceR
Jan 11, 2007 05:52 AM
17
Oct 5, 2006 05:17 AM
CTL
Mar 8, 2004 07:11 AM
under_psi
Mar 27, 2003 03:42 PM
