Real quick b16 questions...
Old Apr 13, 2003 | 01:46 PM
Hybrid Invasion's Avatar
Default Real quick b16 questions...
Ok guys, here it is.. the moment of truth is about an hour away. All I need to know is where the knock sensor specifically is on the b16aSiR1, and what the firing order is on the b16a(obd0), like which spark plug sparks first? I'm pretty sure that the #1 cylinder is the one farthest away from the distributor, but i'm not sure. All I have to do is pop in my dizzy and plug the knock sensor, but i'm having trouble finding the plug for it. HELP! I wanna drive, guys!
Old Apr 13, 2003 | 01:53 PM
Default Re: Real quick b16 questions... (Hybrid Invasion)
bump
RCautoworks's Avatar
Knock sensor is the highest sensor on the back of the block, right below the intake mani.
Old Apr 13, 2003 | 01:57 PM
Default Re: Real quick b16 questions... (90blackcrx)
and as far as the firing order(which plug sparks first)and which cylinder is number one?
Old Apr 13, 2003 | 02:02 PM
Look at the picture, it explains it all.
Old Apr 13, 2003 | 02:03 PM
jdm169's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Invasion &raquo;</TD></TR><TR><TD CLASS="quote">and as far as the firing order(which plug sparks first)and which cylinder is number one?</TD></TR></TABLE>
the spark plug next to cam fires first, in the pic theres #'s on dizzy and cylinders...
I believe firing order is 1324, is that correct
Old Apr 13, 2003 | 02:07 PM
Default Re: Real quick b16 questions... (jdm169)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm169 &raquo;</TD></TR><TR><TD CLASS="quote">
I believe firing order is 1324, is that correct</TD></TR></TABLE>
Which one is next to the cam, there all by the cam ? Did you mean the cam gear ? And I don't understand whats wrong ? The picture shows you what order there in.
Old Apr 13, 2003 | 02:12 PM
jdm169's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Which one is next to the cam, there all by the cam ? Did you mean the cam gear ? And I don't understand whats wrong ? The picture shows you what order there in.</TD></TR></TABLE>
oh duh i'm sorry, yeah i meant cam gears sorry... picture is good
Old Apr 13, 2003 | 02:15 PM
oops, thanks but whats the firing order?
Old Apr 13, 2003 | 02:16 PM
is the knock sensor closer to the pulley side of the motor or the tranny side?
Old Apr 13, 2003 | 02:32 PM
still cant find the knock sensor. can you guys be real specific with me?
Old Apr 13, 2003 | 02:48 PM
is the knock sensor just a little metal stub that comes out of the block, or is it an actual plastic fitting piece to plug the plug in? and do i even need to wire for the knock sensor on a b16a in a 90 crx?
Old Apr 13, 2003 | 04:55 PM
Just Checking In's Avatar
ok so the knock sensor will be here :
Look directly at the back of the motor, do you see your intake manifold, yes? good. ok then look at the left msot portion of it and slowly bring your eyes down to a green plug right below it thats the knock sensor. oh i know....heres a pic on this page, go down to about 1/4 of the way down. click on the word knock sensor to see the pic.
Old Apr 13, 2003 | 04:56 PM
Default Re: Real quick b16 questions... (Just Checking In)
http://b16a.honda-perf.org/theswap.html
Old Apr 14, 2003 | 01:55 AM
your welcome
Old Apr 14, 2003 | 08:55 AM
white99gsr's Avatar
The firing order is 1342. #1 cylendar is furthest from the distributor.
Old Apr 15, 2003 | 05:24 PM
Default Re: Real quick b16 questions... (white99gsr)
ok, what would the consequences be of not grounding the thermostat? Would the car not start? would the thermostat be no good?
Old Apr 15, 2003 | 07:03 PM
It would not start.
Old Apr 15, 2003 | 10:46 PM
NsaneRex's Avatar
firing order is 1342 he he most 4 bangers are!
b16ej6
Jul 29, 2010 11:04 AM
mtownsi
Apr 21, 2007 04:00 PM
Hatch_Back_97
Aug 29, 2006 10:45 AM
Jahtoot84
Jan 6, 2005 11:22 PM
dutchman5
Jan 30, 2004 11:27 PM
