Mig welding on car--damage ecu & other electronics?
How do you guys mig weld stuff while it is still attached to the car? Do you disconnect the ECU and pull the fuses to your electronic gear before you start to prevent damage? Or do you just pull the negative on the battery and roll your dice?
a bodyshop mig welded the badge holes as in, didnt remove anythign and m ycar is fine
Just make sure the welder is grounded ont othe car well (grind away some paint really close to where ur welding)
Okay, I read somewhere that within a few feet of where you weld, the voltage spike is pretty high and *may* damage electronics even if you pull the battery.
HondaJon
Welding / Fabrication
Aug 9, 2005 07:36 PM
