recommended motor build for sc
I would like to know some good products to build a gsr motor to safely boost about 12psi from a supercharger. I don't want to have any problems, blow any gaskets or blow my motor. I want it to be strong so I don't have any worries. thanks. Also what's a good compression piston to use............. thanks.
I would put pistons , rods in and a set of ARP head bolts and you'll be fine.
Try and stay around 10-1 compression , once tuned it will live forever.The rest is just bolt ons to make good power.
[QUOTE=jmcfkya]I don't want to have any problems, blow any gaskets or blow my motor. QUOTE]
then keep it stock!! once you go FI you will have a high chance of all of the above.
That is also true , You buy a Honda and leave it alone it will run for forever. Make it go faster and you will never quit working on in some way or another
Look at my post, That will anwser your question . I have run cars at 10 psi and tuned them and they never come back.
Once you make the car faster , you want to keep going faster. Then it will break , then you have to make it stronger so you can keep making it faster. That was just making light of the sport.
