CRX Gauge Cluster
Old Jun 25, 2001 | 08:57 AM
REDBARON's Avatar
Default CRX Gauge Cluster
Has anyone changed out their cluster, and installed one
from another car? What fits and what doesn't??
I'm planning on installing another engine and don't
really want to get a tachometer.
Old Jun 25, 2001 | 03:05 PM
tysf's Avatar
Default Re: CRX Gauge Cluster (89-T-Rex)
whats wrong with stock?
all crx's come with a tach stock so what are you looking for?
Old Jun 25, 2001 | 04:44 PM
B16CRX's Avatar
Default Re: CRX Gauge Cluster (tylerspec)
I know what you mean. My redline is 8200 now and the stock only reads up to 8000, with redline at 6500. You can use one from an SiR, but they are expensive(usually around $250). You also need an electronic VSS for it to work. I'm not exactly sure what is involved with the install, but supposedly it is not that hard.
Other clusters fit too, just not sure which ones they are.
[Modified by B16CRX, 5:45 PM 6/25/2001]
[Modified by B16CRX, 5:46 PM 6/25/2001]
Old Jun 25, 2001 | 06:08 PM
4thCivicHB's Avatar
New User
Default Re: CRX Gauge Cluster (B16CRX)
If you got the SiR cluster, it would read 180kmh, which is only 112mph. It does not have the conversion reading like the usdm models do. It would be very hard to tell how fast you're going in the US using a JDM cluster. You can get custom guage faces for your cluster though, so you might want to do that with the JDM 180kmh cluster, and get a face that has about 115mph on it, and you could also tune the redline on the tach to where you wanted it. What engine do you have?
[Modified by 4thCivicHB, 3:10 AM 6/26/2001]
Old Jun 26, 2001 | 05:24 AM
4G-CIVIC's Avatar
New User
I think all ef civics/crx's have the same wire plugs for the dashes main harness and gauge pod but I ran into a few problems when I swaped my 88 civic dx dash out for a 90 crx si. I would turn on my lights and both my door open and engine check light come on and my tach jumped to 8k(without engine on). So, there are wires that need to be cut and re-spliced here and there but its not a huge deal I have eliminated most of those now. The confusing thing is that everything plugs in on the guage pod so you'd think it should work but some of the wires are in different pin locations from car to car.
Old Jun 26, 2001 | 05:48 AM
REDBARON's Avatar
Default Re: CRX Gauge Cluster (4G-CIVIC)
Well i have a 89Dx and I'm going to put a vtec motor
in the near future. And i don't really want to get
a Big *** tach because i'm going for the sleeper look.
So I wanted to know what cluster would fit my car that
has a redline at about 8200??
Old Jul 2, 2001 | 10:14 AM
crxgurlllll's Avatar
Best thing would be the SIR cluster..its not very difficult but you have to know what you are doing
Youll need a VSS from a teg for the speedo to work.
Youll need a gas tank sensor from a teg as well if you want the low fuel light to work.
Everything else is just figuring out wiring...
Have Fun!!
Old Jul 3, 2001 | 05:03 AM
TypeR0207's Avatar
Default Re: CRX Gauge Cluster (eraser)
I have a '90 STD hatch, and found an Si cluster for pretty cheap.
This should work based on the info. here, but I am curious as to what I will have to re-wire if anything??
Actually another question, it is an '88-'89 cluster I believe, will it actually work??
[Modified by TypeR0207, 9:05 AM 7/3/2001]
Old Jul 3, 2001 | 05:30 AM
TypeR0207's Avatar
Default Re: CRX Gauge Cluster (TypeR0207)
Okay, the one I'm looking at is an '89 Si cluster.
I need to know if anyone knows if this will work in my '90 STD hatch.
Any help is appreciated!
Old Jul 3, 2001 | 07:31 AM
RyanR's Avatar
No it won't work unless you get the gauge housing from a 88-89. The clusters are different between the 88-89 and the 90-91 models.
Old Jul 3, 2001 | 08:05 AM
TypeR0207's Avatar
Default Re: CRX Gauge Cluster (97TypeR_9)
Cool, thanks. Looks like I'm back on the search for a '90-'91 ......
Old Jul 3, 2001 | 08:07 AM
4G-CIVIC's Avatar
New User
Well if 88-89 are different than 90-91 you just solved my problem.
Thanks,
Ryan
blasterman87
May 9, 2010 07:47 AM
sikefcrx89
Nov 16, 2009 04:13 PM
d4rk13l4de
16
Mar 6, 2009 12:56 AM
976
Mar 29, 2003 11:29 AM
wickedEFguy
Dec 11, 2002 09:58 PM
