Gauge Cluster Question
Old 03-04-2009, 11:20 PM
d4rk13l4de's Avatar
Default Gauge Cluster Question
if i where to buy a JDM gauge cluster out of a civic sir II with the Kph and put guage faces with MPH over it would it be accurate to the MPH?
Old 03-04-2009, 11:34 PM
brown82's Avatar
Default Re: Gauge Cluster Question
I pretty sure it would be off
Old 03-04-2009, 11:46 PM
YoungMoneySi's Avatar
it would be off. your cluster is reading in kilos so putting a piece of plastic in front of it doesn't change anything.
you just have to learn how to convert and if not you can install a kilo-mph converter
Old 03-04-2009, 11:48 PM
brown82's Avatar
ya ur right if u know the conversion then ur golden
Old 03-04-2009, 11:55 PM
d4rk13l4de's Avatar
well on the faces it has both kph and mph
Old 03-04-2009, 11:56 PM
brown82's Avatar
oh ok then ur good
Old 03-05-2009, 12:02 AM
d4rk13l4de's Avatar
faces
cluster
i think the kph marks are the same on the faces just smaller
Old 03-05-2009, 12:04 AM
brown82's Avatar
do have a automatic or man trans?
Old 03-05-2009, 12:07 AM
180 kilos equals 111 mph. there is no way it will work. also, not that it mattes on the speedo but the overlays you are showing are for an automatic
that is a true jdm cluster and if you have one why would you dare touch it by putting overlays? just learn to convert
Old 03-05-2009, 08:27 AM
d4rk13l4de's Avatar
thanks for the info! i will just try not to go to slow lol
Old 03-05-2009, 10:43 AM
BlueIntegraBoy's Avatar
You can buy the JDM cluster, then buy a speedo converter. Automatically converts the KMH to MPH.
Old 03-05-2009, 11:26 AM
d4rk13l4de's Avatar
where do you get those? it would make the 20kph mean 20mph?
Old 03-05-2009, 12:04 PM
hmoobhero's Avatar
just convert them and write it on a sticky post and stick it to your visor. thats what i did and got use to it within a week.
go like:
KPH MPH
10kph = watever it equals
20kph = watever it equals
and so on...
Old 03-05-2009, 12:30 PM
rxbandit1's Avatar
I'm using a JDM cluster too. Don't cover or modify it. Just memorize the common speed limits in your area. You'll be used to it in a couple weeks, and it's bad *** to say your using JDM guages. For example my most common speed limits around my town are 25, 35, and 45 mph. I just memorized those 3 speeds in kph to start, and then the rest is pretty easy to estimate. If in doubt when a cop's near, just go the same speed as everyone else around you. lol
Old 03-05-2009, 01:32 PM
http://cgi.ebay.com/HONDA-SPEEDO-CONVERTER-DELIMTER-KMH-TO-MPH_W0QQitemZ330310784558QQcmdZViewItemQQptZUK_Car sParts_Vehicles_CarParts_SM?hash=item330310784558& _trksid=p3286.c0.m14&_trkparms=66%3A4|65%3A1|39%3A 1|240%3A1318
http://cgi.ebay.com/HONDA-SPEEDO-CON...3A1|240%3A1318
That is correct. 20kmh=20mph
Old 03-06-2009, 12:09 AM
the converter only helps for the miles driven shown onthe cluster. it does not change anything as far as what it says on the gauge layout
Old 03-06-2009, 12:56 AM
Of course it doesn't change what it shows on the gauges. It changes the eletrical output from the VSS, thus converting the KMH to MPH. If it read 60 KMH on the cluster, after the converter, it will be 60 MPH.
philliecrx
10-08-2006 11:33 AM
91sicrxer
06-12-2005 06:36 AM
JDM SLICK
10
05-28-2005 12:27 PM
91sicrxer
19
03-11-2005 03:00 PM
Quick Reply: Gauge Cluster Question
