Car stalls as I'm braking to stop?
Old Apr 12, 2003 | 08:06 AM
EVIL_AWD's Avatar
Default Car stalls as I'm braking to stop?
My cousin has a 1990 Civic with a B18B engine and trans. The problem he's having is that as he's braking, coming to a stop and the car is put into neutral the engines RPM's will drop below 500 RPM and the car will stall. It doesn't have any problems with the idle speed which is at 700-750 RPM and steady. It only happens when he's coming to a stop and puts the car in neutral. The RPM's won't catch and stay above 500 RPM's.
He took it to the dealership and they said that it was his timing and adjsuted the timing for him. It ran ok for about a day and then the problem is back. Does anyobdy have any ideas on what the possible cause may be or did anyone have this problem before?
Old Apr 12, 2003 | 10:11 AM
wronghand's Avatar
Default Re: Car stalls as I'm braking to stop? (ITR420)
Sounds to me like a vacuum issue. I would go through the vacuum lines and look for a problem there.
Old Apr 12, 2003 | 10:42 AM
TRE_'s Avatar
my zc has been having the same exact problems.... it only happens sometimes though. my friend said it may be my idle air control vavle.... bump so both of us can get some info!
Old Apr 12, 2003 | 12:47 PM
smokey2.0's Avatar
Default Re: Car stalls as I'm braking to stop? (glowing_rotors)
last time that happened to me, it was a leak on my TB gasket!
Old Apr 12, 2003 | 01:12 PM
Flexmyrex's Avatar
Default Re: Car stalls as I'm braking to stop? (smokey2.0)
it could be a vacuum leak or a bad distributor
B@re
Sep 14, 2010 12:43 PM
clean3two3
Oct 24, 2007 02:19 PM
yee SERIOUS
Apr 17, 2006 01:58 PM
PRoJecTSLeePaLoT
Jul 31, 2005 07:39 AM
EVIL_AWD
Apr 13, 2003 12:09 PM
