RS Door Handles...
Old Jun 25, 2001 | 08:14 AM
onyx00's Avatar
Default RS Door Handles? Who's Got them? Where can I find them?
I know a few people here changed their door handles to remove the lock switch. I believe this was done with RS door handles. If so where can I get some? I would like to do the same
Old Jun 25, 2001 | 08:19 AM
The Kernel's Avatar
Default Re: RS Door Handles? Who's Got them? Where can I find them? (onyx00)
I got mine from ahmotor.
Old Jun 25, 2001 | 08:20 AM
R0476's Avatar
driver's side: 72165-ST7-023ZA
pass side: 72125-ST7-023ZA
Any Acura dealer.
Hey Onyx00 do have some hook ups on radar detectors?
Old Jun 25, 2001 | 08:39 AM
BlackAckeR's Avatar
Acura (parts) warehouses were out of stock for the last several weeks, probably due to the threads posted about this security enhancement last month... I had mine on order from Acura for about 5 weeks, and they just came in last Friday. Cost was only like $12 for the pair, and they went on easy and look great. Kudos to whoever started this topic!
Old Jun 25, 2001 | 08:44 AM
sackdz's Avatar
Default Re: RS Door Handles? Who's Got them? Where can I find them? (BlackAckeR)
CAn someone post a pic?
Old Jun 25, 2001 | 08:51 AM
Willard's Avatar
Default Re: RS Door Handles? Who's Got them? Where can I find them? (sackdz)
https://honda-tech.com/zerothread?id=39283
Old Jun 25, 2001 | 08:52 AM
yoshi234's Avatar
I shoot brides
the original thread can be found at:
https://honda-tech.com/zerothread?id=26509
Old Jun 25, 2001 | 08:56 AM
D's Avatar
D
on a related topic. i just attempted to install the OEM roof switch to compliment my RS bezels with a functional Door lock switch this past weekend. Works fine, except it has now disabled the power door lock function of my alarm. so, looks like i need to trouble-shoot it a bit when i get a chance.
if anyone wants the pinout for the moonroof switch to convert it over to be used as a power lock switch, i can help out.
D
Old Jun 25, 2001 | 09:11 AM
FBP_1171's Avatar
Default Re: RS Door Handles? Who's Got them? Where can I find them? (D)
How exactly is this a "security enhancement"? If they want your car, they can break the damn window...
I did this a long time ago.
I'd like the pinouts, because I am thinking about hiding a switch somewhere else, like inside the armrest. I have had my car like this for a long time, and I actually haven't found it to be an issue with locking/unlocking the doors from the inside at all.
Old Jun 25, 2001 | 09:20 AM
Mike K's Avatar
Default Re: RS Door Handles? Who's Got them? Where can I find them? (FBP_1171)
Most people who steal cars get in by prying back the driver's window with a screwdriver and reaching in. Pop the power lock with the tip of your finger and you're in there.
I know because I've locked my keys in my car before. You'd be surprised how far a Honda window can flex before breaking.
Also, I have 10 sets scheduled to come to me within a few weeks. These are the RS inner door handles(no lock switch).
They have been on backorder for the past few weeks.
Old Jun 25, 2001 | 09:23 AM
jeff652's Avatar
Default Re: RS Door Handles? Who's Got them? Where can I find them? (Mike K)
Before:
After:
Compare:
Part Numbers:
Old Jun 25, 2001 | 09:24 AM
D's Avatar
D
they also take a long screwdriver, and bend back the door frame at the A-pillar, then flip the power lock switch. no power lock switch, not as easy a break in.
if you can get your hands on a OEM moonroof switch, there are 4 wires on it (make sure you get the wire plug harness)
A GRN/YEL
B BLK
C GRN/RED
D GRN
in order to wire the moonroof switch to operate the power locks, do the following:
terminal B, BLK will be cut and not used
terminal D, GRN will need to be wired to chasis ground
terminal A, GRN/YEL will need to be wired to the power door unlock circuit. this will be a BLK/RED wire if you choose the passenger side lock switch, or a GRN/RED wire if you choose the driver side lock switch.
terminal C, GRN/RED will need to be wired to the power door lock circuit. this will be a BLK/WHT wire if you choose the passenger side lock switch, or a GRN/WHT wire if you choose the driver side lock switch.
Passenger lock button wiring can be found in a large loom of wire in the drivers kick pannel. driver side lock button wiring can be found in the... you guessed it, drivers door. I'm having issues right now because apparenlty where i intercepted the wires, my alarm no longer sees ground through that circuit when arming/disarming. i will modify my connections when i have time and update.
Regards,
D
Old Jun 25, 2001 | 11:02 AM
ITR764's Avatar
same here. my "lock blockers" have been on back order for weeks now!!
Old Jun 25, 2001 | 03:32 PM
Mike M's Avatar
Founding Member
Default Re: RS Door Handles? Who's Got them? Where can I find them? (ITR764)
D Nice idea I didnt even think of that
Old Jun 25, 2001 | 05:42 PM
Unlimited's Avatar
New User
thank you whoever posted this
i bought a set today $25
Old Jun 26, 2001 | 01:38 PM
onyx00's Avatar
Just wanted to let you guys know I just ordered a set from my local Acura dealer, $6 for the drivers side and $6 for the passengers side. Total was $12 plus tax.
Old Jun 26, 2001 | 11:31 PM
Grandprix's Avatar
ummmmmmmmm why dont you just disconnect the lock switch for free fellas??????
hmmmmm???
Old Jun 27, 2001 | 04:49 AM
Unlimited's Avatar
New User
Default Re: RS Door Handles? Who's Got them? Where can I find them? (Grandprix)
lesser chance that somebody will attempt to try to pry your windows to try to unlock the doors
Old Jun 27, 2001 | 08:05 AM
Grandprix's Avatar
Default Re: RS Door Handles? Who's Got them? Where can I find them? (DC231)
ok that is a good point
Old Jun 27, 2001 | 08:09 AM
Willard's Avatar
Without the switch the door totally black without the little chrome thingy there.
Will
Old Jun 27, 2001 | 06:11 PM
JDizzM's Avatar
New User
just ordered mine from bellevue acura (use to work there) and they said they will have it to me by monday.
why is everyone's on backorder?
Old Jun 27, 2001 | 06:27 PM
GRM Scott's Avatar
25 Year Member
Default Re: RS Door Handles? Who's Got them? Where can I find them? (JDizzM)
You'll probably find out on monday (They told me mine would be in a couple weeks ago, until they found out differently)
Old Jun 27, 2001 | 06:36 PM
indy's Avatar
Question,
Do you guys think that by making it hard to break in, the theives might try to come back and think of it as a challenge? What I mean by this is ....
There's another GSR near me owned by an older guy who drives the car as a car nothing more.
Yes a theif can go to him and bust him up which they already did, then they see my car....
"hmm..no VTec badge..BUT GSR rims!, this guy must be into Tegs", says the punk"
Runs over to the car and see's no powerlocks, and cant open hood because of hood lock..
"hmmm this car must have something pretty valuable I am going to take it upon myself as a challenge to get this car" says the theif...
So what I mean is, the more I try to NOT be obvious and make things hard, might steer someone to try my car instead as a challenge???
Indy
Old Jun 27, 2001 | 06:41 PM
Willard's Avatar
Default Re: RS Door Handles? Who's Got them? Where can I find them? (indy)
Well... driving a yellow ITR will be more than enough reason for a person to tamper with my car. Having the door lock switch removed will aid in slowing the thief down. For him to break glass instead of using a screwdriver and a coathanger.... will raise more attention.
I park in a parking deck that police officers use... breaking glass will alert them to foul play.
It is not a theft prevention... mearly a piece in the stages of theft prevention.
Will
Old Jun 27, 2001 | 09:41 PM
Grandprix's Avatar
Default Re: RS Door Handles? Who's Got them? Where can I find them? (Willard)
I dont want to say anything, but you can break into a car like ours in only a few seconds without even touching any glass.
My buddy locked his keys in his car at a car show, and there was a thief there. We asked him to help, and he opened the door in less than one second. It was unbe-*******-leavable. We both just stood there for like a minute with our mouths wide open.
Thats all I have to say about that. So just to let you know.
