do d16y7 & y8 oil pans interchange?
Old Apr 11, 2003 | 10:48 PM
diputs's Avatar
Default do d16y7 & y8 oil pans interchange?
I have a 96 cx with a d16y7 and bought a greddy kit from a guy that included a tapped oil pan from a d16y8. I was looking through the service manual I just got and noticed the y7 and y8 have different pans. (Surprisingly, the y7 has a higher capacity pan.)
Can I use the tapped y8 pan on the y7, and what will I have to do to use it? I'd like to use the y8 I have if I could, but if I must tap the y7, I guess I can. Thanks for any input.
Old Apr 11, 2003 | 11:14 PM
T-sohctec's Avatar
Default Re: do d16y7 & y8 oil pans interchange? (diputs)
if it's the cast aluminum pan it woln't fit. at least it didn' for me.
Old Apr 11, 2003 | 11:24 PM
Smashback's Avatar
Default Re: do d16y7 & y8 oil pans interchange? (T-sohctec)
nope bolt pattern is different
Old Apr 12, 2003 | 12:04 AM
inspyral's Avatar
Default Re: do d16y7 & y8 oil pans interchange? (Hatchblack)
I think the Y8 pan is deeper, as well. I know for sure that Honda increased the capacity between the Z6 and Y8 pans, wich is why the stock Z6 exhaust manifold I'm running temporarily(turbo is getting rebuilt, along with some other issues) rubs my oil pan.
Old Apr 12, 2003 | 12:15 AM
GOLDBERG's Avatar
Default Re: do d16y7 & y8 oil pans interchange? (inspyral)
y8 also has a different gasket..so no they arent interchangable..best bet would be too tap your own y7 oil pan
Old Mar 29, 2004 | 11:12 AM
diputs's Avatar
Default Re: do d16y7 & y8 oil pans interchange? (GOLDBERG)
this is an old thread...I was looking through some of my old posts, and thought I'd give an update. The Y8 pan does fit a Y7. Also, the Y7 is actually higher capacity than the Y8, which I thought was odd.
Old Mar 29, 2004 | 01:54 PM
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diputs &raquo;</TD></TR><TR><TD CLASS="quote">this is an old thread...I was looking through some of my old posts, and thought I'd give an update. The Y8 pan does fit a Y7. Also, the Y7 is actually higher capacity than the Y8, which I thought was odd.</TD></TR></TABLE>
i can also vouch for it fitting. i bought my greddy kit from a guy with a y7 and it fit perfectly onto my y8. no leaks whatsoever.
cvcrcr99
Feb 14, 2010 07:12 PM
JDM96SpecCTR
Feb 4, 2005 02:31 PM
funkfnamna
Sep 2, 2004 11:46 AM
SOHC_MShue
Apr 21, 2004 06:40 AM
tinkfist
Oct 16, 2002 04:28 PM
