y7 oil pan on y8?
y7 oil pan on y8?
hey guys i'm putting a tapped y7 oil pan on my y8 motor. Does anybody know if i will need a different oil pickup tube like from the y7? This is what i read somewhere else.
Re: y7 oil pan on y8? (RyanCivic2000)
Yes, it will work. I put a y8 pan on my y7 block. I know you've got the tapped Y7 pan already, but the y8 pan is about 100x better, and it's thick enough to simply screw in a tap. I know, that's what I did. Couldn't be happier.
I want to be MADE into Ice-T
Re: y7 oil pan on y8? (diputs)
I'll confirm as well, actually SOHC_MSHUE and My self just finished the project, the pan fits great ! and the turbo sounds sweet!!!
Re: y7 oil pan on y8? (yusoslo)
yea too bad i can't even boost yet . The stupid boost program for my ecu must be set up for bigger injectors than I have and it won't run correctly.
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">Are you sure the Y7 pan will even fit? I know the Z6 and Y8 oil pans are not compatible.</TD></TR></TABLE>
I have a Z6 pan on my turbo Y8. You just have to drill out two holes a bit to get it to fit flush.
