anyone here have a single fan radiator on an integra
Old Apr 11, 2003 | 08:07 AM
Mr. Softee's Avatar
Default anyone here have a single fan radiator on an integra
if so, how did you mount it?
Old Apr 11, 2003 | 10:00 AM
Diego Boost's Avatar
Default Re: anyone here have a single fan radiator on an integra (94goldjungsr)
I've got a civic radiator in mine but I had to gheto rig the ****. Here's a link to some pics...
http://www.horsepower411.com/f...did=4
I'm going with a fluidyne very soon and I plan on fabricating a lower bracket for the bump stops on the bottom of the radiator to fit into, then I wont have to use those stupid brackets up top.
Old Apr 11, 2003 | 10:04 AM
RAWB's Avatar
Default Re: anyone here have a single fan radiator on an integra (Diego Boost)
Can you keep the AC with the 1/2 sized rad on an Integra? What do you do with the second fan?
Old Apr 11, 2003 | 10:44 AM
Farnsrocket's Avatar
Default Re: anyone here have a single fan radiator on an integra (RAWB)
I have a PWR Civic radiator in my Teg. I drilled out the stock mounts and then riveted them back in at new locations.
Old Apr 11, 2003 | 11:18 AM
Cramerox's Avatar
i have only one aftermarket fan on my integra. I shut the AC side off because it was rubbing and havent had the time to fix it. actually its been off for a while now. now problems with overheating or anything.
The aftermarket fans were from pepboys and they include everything u need to mount.
Old Apr 11, 2003 | 02:16 PM
Mr. Softee's Avatar
Default Re: anyone here have a single fan radiator on an integra (Farnsrocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Farnsrocket &raquo;</TD></TR><TR><TD CLASS="quote">I have a PWR Civic radiator in my Teg. I drilled out the stock mounts and then riveted them back in at new locations. </TD></TR></TABLE>
can you describe this some more please
Old Apr 11, 2003 | 09:03 PM
johnisenglish's Avatar
Default Re: anyone here have a single fan radiator on an integra (Cramerox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox &raquo;</TD></TR><TR><TD CLASS="quote">i have only one aftermarket fan on my integra. I shut the AC side off because it was rubbing and havent had the time to fix it. actually its been off for a while now. now problems with overheating or anything.
I've got the same thing going on - no A/C fan with no troubles. I figured I'd run it for a while and see if I can into any cooling problems, but I never did, so I never bothered to replace it
Old Apr 12, 2003 | 08:27 AM
Default Re: anyone here have a single fan radiator on an integra (johnisenglish)
This is not the best pic, but here is a shot of my radiator remounted. I just drilled out the 4 spot welds that hold each ot the two original bottom mounts, and then riveted them back in at different location on the front support of the car.
rotten
Northwest (Sales)
Aug 12, 2006 06:12 PM
IntegracinGSR
Feb 3, 2004 04:51 AM
h22civic95coupe
May 16, 2003 12:51 PM
fastbrakes
Dec 28, 2002 03:52 AM
dfoxengr
Jul 19, 2002 10:24 PM
