vafc + pr3 ecu
Old Apr 10, 2003 | 05:59 PM
slowpokesi's Avatar
Default vafc + pr3 ecu
do you hook up the vtm wire? if so what do u hook it to?
any body have extra instructions on what to do with the vafc? the manual doesnt cover pr3 ecu's
Old Apr 10, 2003 | 08:49 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Default Re: vafc + pr3 ecu (slowpokesi)
I havent done one for awhile, but i remember using all the wires. The manual does cover the PR3 ecu. Follow the instructions for the 88-91 Integra XSI or 88-91 Civic SiR.
-Todd
Old Apr 10, 2003 | 08:53 PM
slowpokesi's Avatar
Default Re: vafc + pr3 ecu (Count Blah)
okay i figured that out.
my question now is about the pressure signal, is that for the vtec pressure switch or for fuel pressure.
because according to the manual it says c11 wich is the map sensor
Old Apr 11, 2003 | 04:18 AM
slowpokesi's Avatar
unf unf
Old Apr 11, 2003 | 04:36 AM
sleeper4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">okay i figured that out.
because according to the manual it says c11 wich is the map sensor</TD></TR></TABLE>
i dont get it. if the manual says that you wire up the VAFC to C11 which is the MAP sensor, why would you be guessing if this wire is for the vtec pressure switch or for fuel pressure??
the pressure signal wires are for the MAP sensor (for fuel enrichment), VTEC is already connected with the wire running from A7 and the VAFC has NO control over fuel pressure.
Old Apr 11, 2003 | 05:35 AM
slowpokesi's Avatar
how many wires on the motor are labeled pressure? only 1 the vtec pressure switch
thats why i was confused.
the manual should say map sensor, itd be less confusing, thanks for clearing everything up though
Old Apr 11, 2003 | 07:51 AM
sleeper4dr's Avatar
Default Re: (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">how many wires on the motor are labeled pressure? only 1 the vtec pressure switch
the manual should say map sensor, itd be less confusing, thanks for clearing everything up though</TD></TR></TABLE>
and.. what about the Manifold Absolute Pressure Sensor?
Old Apr 11, 2003 | 08:01 AM
slowpokesi's Avatar
Default Re: (sleeper4dr)
dont give me a hard time dude,
thanks for anwsering my question dont be a dick , i obvously didnt think about it before.
Old Apr 11, 2003 | 08:08 AM
zCivic's Avatar
ok here we go the VTM wire goes to B5 which is the same wire as Oil Pressure on a PR3/PWO ECU. If your using a PM6/PG7 USDM ECUs its for the ELD and you don't wire it up. Hope this helps B11 is for the map sensor...cut the wire in half....connect the Yellow wire to the ECU side of the wire then the white goes to the remaining going to the map sensor
Modified by zCivic at 12:28 PM 4/11/2003
_Endless_
May 16, 2003 06:24 PM
juicy.koreans.suck
Apr 18, 2002 06:51 AM
juicy.koreans.suck
Apr 11, 2002 08:56 PM
VTECHGSR
Dec 13, 2001 04:30 PM
